'99 - ML430 HORN - Page 4 - Mercedes-Benz Forum
post #31 of 38 (permalink) Old 01-14-2013, 09:29 AM
Date registered: Aug 2006
Vehicle: 02 ML320 06 ML500
Quoted: 925 Post(s)
Originally Posted by Oeschj View Post
Good point. I will have to take it to the dealer for the SRS light. Doubtful that it will lead me to the cause of the horn not working, but its worth a shot.
The SRS circuit and the horn circuit run through the clock spring. Probably the tape probably partially broke inside causing the SRS light to come on and then the rest of the tape broke resulting in no horn.
Find an independent mech. with a good scanner and he can read the Air Bag codes. If it comes back that the driver air bag has a problem, then replace the clock spring and you will get the horn back. The you will have to return to the indy. to clear the air bag code.
43sqd is offline
post #32 of 38 (permalink) Old 01-14-2013, 12:19 PM
Oeschj's Avatar
Date registered: Oct 2010
Vehicle: 2000 ML430 (Sold)
Ah, i hope so. At least it would be an end to the mystery. Wouldn't it be just as beneficial if i tore the spring out and investigated myself BEFORE having the codes read?
Or is the clock spring not a DIY? The WIS on it seems easy in theory but the terminology makes it seem hard.
Oeschj is offline
post #33 of 38 (permalink) Old 01-14-2013, 05:40 PM
Quoted: 925 Post(s)
Yes it is a DIY, just as long as you have a 2 ft. long, 1/2" breaker bar and correct socket to remove the bolt at the steering wheel.
43sqd is offline
post #34 of 38 (permalink) Old 01-14-2013, 05:57 PM
Oeschj's Avatar
Thanks for all the tips. Truck us going in to my indy who has a Snap On scanner and will get me the source of the SRS.
Just in case, does anyone know the size for the nut holding the steering wheel on?
50% of the time, its the brake light switch 100% of the time.
The other 75% of the time it's not.
Oeschj is offline
post #35 of 38 (permalink) Old 01-14-2013, 06:30 PM
Merzatt's Avatar
Date registered: Nov 2007
Vehicle: ML320 2002 Cayman S 2014
Quoted: 79 Post(s)
"#10 hex wrench"
http://www.benzworld.org/forums/w163...er-remove.html
Merzatt is offline
post #36 of 38 (permalink) Old 01-14-2013, 06:37 PM
Oeschj's Avatar
Originally Posted by Merzatt View Post
Great find. Thank you very much. Are you sure its the same for a 2000? The air bag electronics are different i can see, hopefully thats all that changed.
Sent from my iPhone using AutoGuide.com Free App
Oeschj is offline
post #37 of 38 (permalink) Old 01-17-2013, 09:37 AM
Oeschj's Avatar
Never got a print out of the codes, but SDS points towards clock spring. Scheduled for tuesday to go back to the dealer and get it done. 220.00 for the part and 1 hour install at 145 an hour.
Oeschj is offline
post #38 of 38 (permalink) Old 02-25-2013, 08:12 PM
Oeschj's Avatar
Just wanted to add an end to my story. It was the clock spring. Got my horn back and SRS light is off. Thanks guys, and you were right again 43SQD.
Oeschj is offline
    2001 ML430 Alarm horn Pikes W163 M-Class 7 01-20-2010 06:31 AM
    Horn stop working, where is the fuse for the horn njstreeter W203 C-Class 1 09-09-2008 09:53 AM
    Will 2001 Ml430 transmission work in a 2000 ml430? orlandotrader W163 M-Class 3 02-24-2006 04:31 AM
    WHICH HORN IS WHICH janos_z W126 S,SE,SEC,SEL,SD,SDL Class 13 01-01-2006 11:02 AM
    Is there a "horn mod"? My horn seems a bit soft and more of a beep than a HONK. Thanks. J-bird W163 M-Class 36 12-02-2003 08:40 PM
