99 ML320 showed various trouble codes a year ago, I changed plugs, pulled the EGR tube and unclogged it. When I pulled the EGR tube on the back of the engine, I checked to see if the solenoid on the EGR was free. I pushed it and it clicked and moved, so I thought maybe it had frozen and maybe pushing it freed it up. It ran fine for about a month, then it started acting up and gave codes for MAF sensor, O2 sensors, random misfire (cylinders 1 & 3). It sat for a while because I didn't have time/money to mess with it, and the battery went kaput on me as well (wouldn't hold a charge, even after a long trickle charge etc.)
About a month ago I changed the MAF sensor and 2 coil packs. Yesterday I gave it a new battery and limped it to Autozone to check the codes and came back with a single P1400 code, which referenced the MAP sensor (according to Chrysler OBDII, they didn't have Mercedes readouts.) I checked my hoses and found some bad ones, which I replaced but it didn't seem to matter. I haven't done a vacuum vs voltage test on the MAP, but was looking for specs here and I referenced the forums and keep seeing the EGR Changeover Valve Switch mentioned with the P1400 code.
Problem is, depending on where I look, there seem to be 2 of them. One is mounted on the EGR Valve itself, and the other is mounted on the same bracket with the MAP sensor on the front of the engine. When I look up the part online, all I see is the sensor that mounts to the EGR Valve, and the one on the front of the engine looks different. Which one do I change, the MAP or EGR Changeover(s)? Or do I change both (or all 3)? Am I looking at updated parts differences between the Changeover valves because they look different? I'm getting tired of throwing parts at the dang thing, but I've spent much less money replacing things myself than having the shop do it.
