SRS Light Code B1315 - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W163 M-Class
Old 08-30-2010, 06:22 AM   #1 (permalink)
Date registered: Aug 2010
Vehicle: ML 270CDi 2003
Hi all,
bitu is offline   Reply With Quote
Old 08-30-2010, 03:09 PM   #2 (permalink)
Date registered: Aug 2006
Vehicle: 02 ML320
The only thing you can do is check the 3 wire (Red, White and Brown) connector under the passenger seat. If it is properly connected then you need a new seat sensor. You are not the first one to have this problem; many have come before you.
It is not easy to check this problem. It requires the removal of the console as to gain access to the SRS control module. Do you really want to do that?
43sqd is offline   Reply With Quote
Old 09-07-2010, 04:14 AM   #3 (permalink)
Was hoping it would be a simple test, never mind. Thanks for the help and advise.
Bookmarks
SRS light stays on and SRS DTC strange result nubyOz W140 S-Class 8 11-25-2010 09:57 PM
SRS light and Restraint code Error on dash dhctrading W209 CLK Class 1 03-01-2010 01:15 AM
Error Code Po161/ SRS light issue kdude87 W210 E-Class 11 06-20-2009 08:38 PM
2002 c 230 check engine light and srs light upstaterider2003 General Mercedes-Benz 4 08-04-2008 07:35 AM
ABS acting up , srs light being funny , brakes weird, oil light sometimes flashes jimmypop W126 S,SE,SEC,SEL,SD,SDL Class 11 10-03-2007 06:04 PM
