» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W163 M-Class
Old 02-17-2002, 02:21 AM   #1 (permalink)
PDo
Guest
Posts: n/a
02 Bi-Xenon Added to 02 ML320 - MCS Programming?
I talked to one of the technicians at the dealership about adding the 02 Bi-Xenon to my 02 ML320 the other day. He said it is pretty much plug-n-play, but he also has to go into the car’s computer (MCS?) for additional programming so that the system knows that Bi-Xenon are installed.<br> <br> Obviously I will not get the headlight washer system retrofitted because that will require changing the bumpers, but why is programming necessary. Does this have to do with the auto-leveling feature? Or maybe he is just trying to discourage me from doing the installation myself?<br> <br> I will pay him another visit for clarification and details – but I wanted to post this question here because I trust this forum’s collective knowledge about our loved MLs.
Old 02-17-2002, 02:49 AM   #2 (permalink)
Drew
Guest
Posts: n/a
Re: 02 Bi-Xenon Added to 02 ML320 - MCS Programming?
Actually, I think that he may be correct. I do know that there is some version coding for the '02s and you could damage the lamps if this is not done probably (voltage issues, I believe). I'll try to find out more on this next week.<br> <br> No, it has nothing to do with autoleveling. You will not have it since it requires other (very expensive) hardware and installation.
Old 02-17-2002, 02:50 AM   #3 (permalink)
Drew
Guest
Posts: n/a
Oh it has nothing to do with the MCS, BTW.
Old 02-17-2002, 02:54 AM   #4 (permalink)
PDo
Guest
Posts: n/a
Thanks Drew - I would appreciate as much info as you can find.
Old 02-17-2002, 02:56 AM   #5 (permalink)
Drew
Guest
Posts: n/a
I'll let you know if I find out more...
I'll have to go and bother the shop foreman, heh heh, so it may take a little while. I'll also check if the wiring pinouts are the same.
Old 02-17-2002, 12:19 PM   #6 (permalink)
Chris Krikorian
Guest
Posts: n/a
Wiring pinouts for 2002 bi-xenons and 2002 halogens are the same.
Old 02-17-2002, 12:33 PM   #7 (permalink)
Drew
Guest
Posts: n/a
Great, one down...
the version coding issue with the AAM still has to be resolved though.
Old 02-18-2002, 03:12 AM   #8 (permalink)
Iwan
Guest
Posts: n/a
I've heard about this problem when upgrading to xenons either OEM or aftermarket kits. I don't know if it applies to the ML but in the new C class where you have the multifunction display (in the center of the speedometer) if you upgrade to xenons a headlamp error sign will appear, athought the the lights are functioning properly. The car's computer has to be reprogrammed to recognize the xenon's. In the ML, I assume that our system is not as complicated and we don't have such display which I think why it won't be a problem not at least in the 98-01 models. This has been proven by myself and others who have installed the xenon lights in their ML.
Old 02-18-2002, 11:25 AM   #9 (permalink)
Ped Perez
Guest
Posts: n/a
Just curious, how much is your dealer asking for the Bi-Xenon ? I also asked my dealer how much to install it on my ML-500, and he quoted me $2000. He said the cost includes re-wiring to handle the increased voltage/ampere requirement.
Old 02-18-2002, 01:21 PM   #10 (permalink)
Drew
Guest
Posts: n/a
Iwan...
There is apparently some sort of setting for the '02 MLs for the Bi-Xenons, at least according to the shop foreman I conversed with. I'm pretty sure I know why, but I'll check this out before I say anything.
