2000 ML430 BAS ESP ABS light comes on when turn wheel to the right - Mercedes-Benz Forum
post #1 of 16 (permalink) Old 08-27-2010, 07:00 AM Thread Starter
Date registered: Aug 2010
Hello all! i am new and have enjoyed the all info i have read. here is my issue: 2000 ML430 BAS ESP ABS light comes on when turn wheel to the right. I believe there were actually 2 issues but i have managed to repair all but this last one. Initially, i could also feel the ABS activating interrmittently when pressing the brake. below is THE list:
Step 1 - replace brake switch - no change
2. - check tire pressure and size - good
3. - test battery with it started or not with a voltmeter - 12.4v & 13.8v-good
4. - remove battery cable for 3 minutes to reset then recalibrate - no help
5. - check transmission connector & found fluid! Cleaned it. ABS issue fixed!
Some maintenance history: all brakes were replaced about a year ago, tires new about 2 years ago, 210,000km, truck drives only about 12,000km/year.
Test drove & lights went out after cleaning the tranny connector. Turned wheel all the way to the left & no problem. Turned wheel all the way to the right and the lights came on again. If I drive for a bit & shut off vehicle the lights will go out until the infamous sharp right turn. The moment the 3 lights come on the ABS will go off(when press brake).
I suspect wheel sensor or wiring?
Willowwayne is offline
post #2 of 16 (permalink) Old 08-27-2010, 11:39 AM
AlexLs1's Avatar
Date registered: Jan 2009
Few weeks ago I started my 2000 ML430 and it would start fine but the radio would ask for a security code and that BAS ESP light would appear on the cluster. However it would turn off after I would start driving a few feet. I took it to get looked at. My battery was in need of replacement. It was replaced, but the BAS ESP light still appeared at idle. Greg Fura (MB trained in Germany Mechanic at TanzTech here in Sarasota, FL) instructed me too straighten the wheel, turn it to the left, full lock. Then turn it all the way to the right, full lock.
It worked for me, I hope you have the same luck. Your just resetting the sensor.
W163: 2000 Silver ML430 Sport
AlexLs1 is offline
post #3 of 16 (permalink) Old 08-27-2010, 12:43 PM
Date registered: Jan 2007
Vehicle: 1999 ML320 Elegance, BMW R1150RT, SAAB 9-3
Quoted: 5 Post(s)
1/ please fill in your profile.
2/ re; 5. - check transmission connector & found fluid! Cleaned it. ABS issue fixed!
you should change the connector as it will most likely just leak again
3/ when you are turning the steering wheel - is the car moving forward or stationary?
edit: i reread your post.... i assume moving... i assume the abs activation and the bas-abs light illumination are simultaneous..
4/ check for codes!
5/ assuming abs light comes on if the car is moving the wheel sensor does indeed seem extremely likely (to my un-expert opinion . maybe search on how to test wheel sensor(s). as a minimum you might try cleaning and inspecting all 4.
good luck.
Unhofliche_Gesundheit is offline
post #4 of 16 (permalink) Old 08-27-2010, 01:40 PM
Date registered: Jul 2005
Quoted: 972 Post(s)
+1 on the trans connector. I am sure it is the 13 pin unit known as the pilot bushing.
MB has an improved design with better sealing and more durable o-rings and they
are very inexpensive.
As far as the other items please try the suggestions already posted and more than likely
people here will help you solve the problem.
Noodles is offline
post #5 of 16 (permalink) Old 09-15-2010, 10:02 AM Thread Starter
Update: i had it to the dealer. they did not tell me info about the codes but did test a bad/interrmittent wire lead for one of the wheel sensors. It is orderd and i scheduled for a return visit. they estimate one hour ($140) plus part. has anyone ever relaced one of these on their own?
post #6 of 16 (permalink) Old 10-27-2011, 09:46 AM
Date registered: Oct 2011
Vehicle: 2000 ML430
i have the same problems but my srs and battery light is also coming on too. i got a new battery in and it started and drives perfectly but the battery light srs esp bas abs ligghts are all on?
K.Lor is offline
post #7 of 16 (permalink) Old 10-27-2011, 11:49 AM
Date registered: Aug 2006
Vehicle: 02 ML320 06 ML500
Quoted: 881 Post(s)
Please UPDATE YOU PROFILE.
Did these lights come on after you changed the battery?
43sqd is offline
post #8 of 16 (permalink) Old 10-27-2011, 01:14 PM
Vehicle: 2000 ML430
no but the battery light was still on after i change the battery and the next morning they all just came on but now there gone but battery light is still on?
K.Lor is offline
post #9 of 16 (permalink) Old 10-27-2011, 01:26 PM
Quoted: 881 Post(s)
You now have to check your charging system with a digital volt meter. The BATTERY being on could mean either the battery or the alternator being faulty.
43sqd is offline
post #10 of 16 (permalink) Old 10-27-2011, 01:29 PM
Vehicle: 2000 ML430
will it cant be the battery because its new and im hoping its not the alternator but one thing i dont get is why is m y bas esp abs ans srs all coming on too
K.Lor is offline
    2000 ml abs bas esp lights on loss of breaking on a turn??? luvinlife W164 M-Class 2 10-27-2011 10:07 AM
    2000 ML430 BAS ESP ABS light comes on when turn wheel to the right Willowwayne General Mercedes-Benz 0 08-20-2010 08:40 AM
    99 ml430:BAS ESP,ETS,ABS LIGHTS ON hchambi W163 M-Class 7 04-04-2010 08:21 PM
    2001 ML430 with 139k miles BAS.ESP.ETS.ABS all 4 are on hksnlper W163 M-Class 2 12-26-2009 04:31 PM
    2000 W210 BAS/ABS/ESP marcmerc W210 E50 AMG, E55 AMG 2 02-24-2008 06:01 AM
