resync key fob ml320 - Page 2 - Mercedes-Benz Forum
post #11 of 38 (permalink) Old 10-14-2013, 08:34 PM
Date registered: Oct 2013
Vehicle: Jetta
I used to have this problem as well. Keyhole's advice is 100% correct and accurate!
jdog55007 is offline
post #12 of 38 (permalink) Old 12-30-2013, 09:01 PM
Date registered: Jul 2008
Originally Posted by mike407 View Post
I have a 2001 ML320 w163. I tried this and was successful in locking the doors, and it appeared to activate the car alarm - the red light next to the radio display came on, and although no noise, if I opened the car door after following this procedure, the hazard lights would begin flashing until I put the key back in the ignition.
My result is that when I finish these steps, the doors lock, but if I hit unlock or any button after that, there is no response. Has anyone else had a similar response? The batteries are brand new and there is no visual damage to the battery contacts.
I'm having the same problem. Please help!!
babbar187 is offline
post #13 of 38 (permalink) Old 04-02-2014, 02:23 AM
Date registered: Dec 2012
Vehicle: 2006 ML320 CDI
Mine is also working now. Thanks Keyhole. Have a good one!
scheep is offline
post #14 of 38 (permalink) Old 07-19-2014, 10:28 AM
Date registered: May 2009
Thanks Keyhole
Originally Posted by keyhole View Post
You have a W163, right?
Your synch was not quite right. Try this. According to the WIS, the sequence must be completed in 10 seconds!
1. Insert the key into ignition and turn to position 2.
2. Remove the key, and press the LOCK button, and hold it pressed while simultaneously pressing the UNLOCK button 5 times.
3. Now release the buttons, and press either the LOCK or UNLOCK button once.
That should re-synchronise the key. Let us know if it works for you.
Just a quick note to say thanks Keyhole, I used your instructions to sync the Fob and they worked FIRST TIME!!! Greatly appreciate it!!
HabFann is offline
post #15 of 38 (permalink) Old 07-25-2014, 08:22 AM
Date registered: Jul 2014
Vehicle: 2001 ML320
Just purchased a well used 2001 ML320. Came with two fobs, neither work. I tried to resync them and on one of the keys the dome light turns on at the end of the resync process, but it still does not work. What would the next step in troubleshooting be? My console 'lock all' button works fine. Thanks!
Farls is offline
post #16 of 38 (permalink) Old 07-25-2014, 03:31 PM
Date registered: Jul 2005
Quoted: 1016 Post(s)
I am assuming you have put new CR2025 batteries in each remote?
Noodles is offline
post #17 of 38 (permalink) Old 07-25-2014, 09:41 PM
Vehicle: 2001 ML320
Sorry, should have mentioned that - new batteries on both keys. One of them seems to sync (the dome light turns on and off after the resync), but it will not unlock or lock the doors.
Farls is offline
post #18 of 38 (permalink) Old 07-26-2014, 12:17 AM
Kajtek1's Avatar
Quoted: 1197 Post(s)
Its been few years since I drove ML class, but I remember that keys were user- synchronizable till the year 1999 or 2000.
Newer years take SD and dealers rip-off charges.
Kajtek1 is offline
post #19 of 38 (permalink) Old 07-26-2014, 03:22 AM
I took this from the page in a 2001 PDF version of the manual.
It appears for 2001 the key should sync with these instructions. The timing they give in the directions is crucial.
Clicking on the image will make it larger and easier to read.
Noodles is offline
post #20 of 38 (permalink) Old 07-27-2014, 03:01 PM
Kajtek1's Avatar
It is remote synchronization, not the key.
Would be good time to specify what exactly is the problem.
The "fob" usually is used to describe blade-less key.
W163 did have all switchable blades as far as I know.
Kajtek1 is offline
    resync key fob ml320 rzogheb General Mercedes-Benz 0 08-22-2010 12:01 PM
    Mercedes Resync New Key BS rennwerkes W210 E-Class 30 09-05-2009 05:35 PM
    IR Key Fob C43 W202 C36 AMG, C43 AMG 8 08-20-2009 12:12 PM
    Key Fob Ronw435 R129 SL-Class 1 04-04-2009 12:57 PM
    Key Fob celm W210 E-Class 16 02-03-2009 01:56 PM
