Can I replace an a/c compressor on my own? HELP! - Mercedes-Benz Forum
post #1 of 13 (permalink) Old 08-17-2010, 09:27 AM Thread Starter
Date registered: Aug 2010
Vehicle: 1998 ML320
It has been REALLY HOT in the south this year.
Of course, the A/C in my 1998 ML320 went out(how convenient). So, knowing very little about this ML(I inherited it), I took it in to the dealership expecting to pay $1,000+, have a mild heartattack, but survive.
I had to sit down this morning when my dealer(MB-S. Atlanta) told me that my compressor was not working and needed to be replaced along with the expansion valve. TOTAL = $2,100
I paused on the phone and told the service guy, "I'll have to call you back..."
So, here I am, frantic for an answer. I superficially searched the forums and found diagrams, but not enough detailed information to determine whether I can do this, use my local mechanic to do this, take my whippings at the MB dealer, or turn the ML into a winter-only vehicle.
So, Mr. Reader, hopefully you or someone out there in Benzworld has the answer to the questions...
Can I do this on my own? If not, why?
What do I need to ask the dealer before I fork over $250 to them for telling me the bad news???
Thanks for any help you can provide...
tomenki is offline
post #2 of 13 (permalink) Old 08-17-2010, 11:02 AM
Vehicle: 1990 190E 2.6,.... 1998 ML320, 2005 ML500SE
Quoted: 65 Post(s)
It's either the stealer or a reputable AC service shop. I would not let the local mechanic do the work. AC systems can be really FUBARed by someone that does not know what they are doing and who does not have the proper equipment. The dealer is going to take the safest way out and replace the compressor and related stuff. You may only need a charge. If you work with a certified AC shop they may let you change out the compressor if that is what you need and they could finish up the install with whatever else is needed.
(Just a thought)
Mike
[EDIT] --- I would take it to a certified AC shop and if all it needs is a charge than I would refuse to pay the $250 for the false diagnosis.
Mike's ML is online now
post #3 of 13 (permalink) Old 08-17-2010, 11:39 AM
Date registered: Sep 2009
Vehicle: 2000 Mercedes ML55 AMG
i changed my compressor myself and just got a shop to charge it for me.
Brettriehl101 is offline
post #4 of 13 (permalink) Old 08-17-2010, 12:13 PM
rudedude's Avatar
Date registered: Jul 2005
Vehicle: ML320,C230, F250, Bayliner, Mountain Bike, Fleetwood Motorhome etc...
Yes it is very easy to change an A/C compressor. The problem is if the compressor is bad then you need to replace the filter drier too because pieces of metal from the compressor will go in there. Also you need to evacuate and recover the freon in the system. Then you will need to vacuum the system to remove all moisture after it is all put back together. If you don't have the tools to vacuum the system you can rent a vacuum pump from places like Auto Zone... Don't forget to add the proper amount of oil in the new pump.
True success is being the master of your own time.
rudedude is offline
post #5 of 13 (permalink) Old 08-17-2010, 12:37 PM Thread Starter
Vehicle: 1998 ML320
How long did the job take?
tomenki is offline
post #6 of 13 (permalink) Old 08-17-2010, 12:59 PM Thread Starter
Vehicle: 1998 ML320
(Just a thought)
Mike
I talked with the dealer this afternoon and he said that they did evacuate and charge the system, but without the compressor working, they don't know what other problems there might be besides the compressor being bad. The service "advisor" said that even with voltage put to it, the compressor refuses to budge.
His personal view is also that it would be a great winter car.
tomenki is offline
post #7 of 13 (permalink) Old 08-17-2010, 01:06 PM Thread Starter
Vehicle: 1998 ML320
Thanks for the advice...How easy was it to access the compressor?
Also, how much $$$ for all of the parts? Looks like around $600...does that sound right?
BTW, I am picking up the ol' ML this afternoon so I can look around in it and make a decision.
You know, it still drives great for 226,000 mi...it's just the comfort factor.
Again, thanks for your help.
tomenki is offline
post #8 of 13 (permalink) Old 08-17-2010, 05:13 PM
Date registered: Jul 2006
Vehicle: 1999 E55, 2001 E320, 1990 560 SEC, 2004 ML350, 2001 ML55, 1995 S500, 1998 SL500, 2010 E550 Sport zoo
Quoted: 127 Post(s)
This is the parts deal, you can replace compressor/engine compartment parts for under $400:
Required: new compressor (new Behr China great value) + seals kits = like $260:
1996 - 2008 Chrysler Dodge Mercedes New A/C Compressor
Required; drier, get OE, not knockoff = $36
Your Parts Search Returned 1 Part(s)
Required: expansion valve, get OE Denso = $40
Optional, but recommended, new condensor - there the updated condensor is like $130-$160, but could need new drier-to-condensor line for another $60.
Pull the trigger on the right parts, then shop for a shop for the install...
Keep the faith !
fabbrisd1 is offline
post #9 of 13 (permalink) Old 08-17-2010, 07:28 PM
Vehicle: '05 ML350SE
fabbrisd1:
I have to ask this. What connects Arkansas with La Jolla and Hong Kong?
Tom DeTemple
Denver
'99 ML320 traded @139k miles for---
'02 ML320 traded @45k miles for---
'05 ML350SE now at 127k miles
mickey.1430 is offline
post #10 of 13 (permalink) Old 08-18-2010, 06:57 AM Thread Starter
Vehicle: 1998 ML320
Great Reply!
Keep the faith !
Thanks for the post! I will definitely heed your advice and source these parts.
I'll make sure and post again when I have them and report back with prices.
tomenki is offline
    ANyone know how to replace compressor clutch on OM617 while compressor still attached to loss W123 E,CE,D,CD,TD,TE Class 16 06-22-2010 10:26 PM
    Compressor always on - replace ECU ??? saxmanjack R170 SLK-Class 10 09-24-2009 09:18 AM
    A/C Compressor Clutch - Replace/Rebuild?? Surfin' Elvis W126 S,SE,SEC,SEL,SD,SDL Class 8 08-15-2008 01:02 PM
    How to Replace Ac Compressor? Louie_D W126 S,SE,SEC,SEL,SD,SDL Class 1 11-08-2007 05:18 PM
    How much to replace an ac compressor, 1987 560sl mschiavone2 R/C107 SL/SLC Class 4 09-21-2006 03:04 PM
