ml 270 cdi engine pulley has developed a squeak - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 08-08-2010, 06:24 AM Thread Starter
Date registered: Aug 2010
Hi all i'm new to this forum and just like some tech help
My problem is that i own and drive a merc ml 270 cdi i have owned and enjoyed driving the motor for 3 happy months but this morning i came to the car and started it and heard an unusaul noise coming from under the bonnet.
Now i'm no mechania but do have a little knowledge about cars.
The noise its self is an intermittent squeal/squeak coming from one of the engine pulleys at the front of the engine? is this an easy fix or am I in trouble(should i stop driving it?) Its on of the pulleys at the top of the engine in the middle of the top three group of pulleys Any help would be grate fully appreciated thanks again scott ps it isnt the belt its more of a bearing dry bearing type squeal!
ml270cdi_scottyB is offline
post #2 of 3 (permalink) Old 08-08-2010, 07:02 AM
Date registered: Aug 2006
Vehicle: 02 ML320 06 ML500
Quoted: 919 Post(s)
You will have to remove the serpentine belt to determine which pulley is at fault, but in all probability it will be either the tensioner or idler pulley. After the belt is off a spinning by hand will determine which one it is.
Also while you have the belt off, you mind as well change it .
43sqd is offline
post #3 of 3 (permalink) Old 08-08-2010, 07:02 AM
boardboy330's Avatar
Date registered: Mar 2008
Vehicle: 2000 ML320
Quoted: 57 Post(s)
Send a message via AIM to boardboy330 Send a message via Yahoo to boardboy330
Depends on which pully. On gas models...the idler and tension pulley were often replaced...and the harmonic balancer was also an issue. HB was about $200...Idler is $20-30...tensioner is $120 or so. Belts are $30. Can you post videos or a diagram?
"I'd rather peel off my skin and bathe my weeping raw flesh in a bath of vinegar than spend any time with you. But that's just my opinion. Don't take it personally."
(\__/)
(o.O )
(> < ) This is Bunny. Copy Bunny into your signature to help him on his way to world domination
2000 ML320
boardboy330 is offline
    finding engine number ML 270 CDI pleun General Mercedes-Benz 1 02-10-2009 01:40 AM
    SUITABLE ENGINE OIL 2001 E 270 CDI scotland W210 E-Class 3 12-06-2008 07:28 AM
    270 CDI Engine longfellowclk C209/A209 CLK-Class 1 06-04-2008 04:34 AM
    US 270 CDI Conversion Using Sprinter Engine ez rhino G-Class 20 05-27-2008 02:40 PM
    A squeak has developed, which is coming from the real... Tom (Vancouver) R170 SLK-Class 8 09-24-2002 08:33 AM
