rough idle ml320? - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 04-07-2010, 07:11 AM Thread Starter
hyprr1's Avatar
Vehicle: 2002 CL55 AMG, 1993 190E 2.3L
Quoted: 22 Post(s)
Send a message via Yahoo to hyprr1
rough idle ml320?
Ok this is the deal. I've own my ML for 2-3 months now and it's been great, so far!
But one week ago I put some gas from a station out in no-man's land. I was running fairly low, so I stopped
and filled her up. I usually use the middle brand of gas. As I approached my fill up, I noticed a lady in a 2007
Altima that had just finished pumping gas in her car. When she tried to start her car, she had to crank it 6-7 times until
it started. I didn't think anything of it. My ML started no problem, but the next day the issue started. CRAZY rough idle.
I poured some Octane boost & water remover and it solved the problem within 10min. The next fill up I used 94 octane and the
problem came back......My truck is running so bad. It has a rough idle and feels like it's mis-firing (sputter). It still idles around
600-700 rpm, but the needle bounces a bit up and down. No CEL, just crapy running ML320.............
Any ideas???
Fuel filter?
spark plugs?
coil pack?
Spiros aka "1BADAMG".....
hyprr1 is offline
post #2 of 10 (permalink) Old 04-07-2010, 07:27 AM
Date registered: Nov 2009
Vehicle: 99 White ML320, 13 Audi S5,84 300ZX Turbo, 03 Audi A4, 03 Audi TT, 65 Ford Galaxie Conv
Quoted: 11 Post(s)
Maybe the Altima was just coincidence? You wouldn't think a late model Altima would have any other problems and that first start Should be on the "good" gas from the lines. If anything, I would think what your ML did would be more indicative of bad gas (starts fine, runs okay for a while, then develops problems).
Anyway, some of the more experienced guys may have suggestions, but I think you answered your own question with the fuel filter thought. Seems like it would take longer for plugs to foul.
lyleswk is offline
post #3 of 10 (permalink) Old 04-07-2010, 08:00 AM Thread Starter
hyprr1's Avatar
Quoted: 22 Post(s)
Yeah your right. I haven't really performed a tune up on my ML yet, but I think I'll
start with the fuel filter.
The Altima did start at first because of the exsisting gas, but she actually turned into
the coffee shop which was next door to the gas station. She then came back out after getting her coffee and that's when she had trouble starting the car.
In the meantime I was filling my truck and noticed this whole situation. It was just so weird?
Basically before I filled up at this station, my ml ran amazing. Since this gas fill-up (a week ago) my truck has been running so bad. I'm letting it go 1/4 empty and then I'm going to Sunoco and filling up with 94 Octane. And if that doesn't work, I'll start performing a general tune-up (plugs, filters, etc.....).
I've never experienced this with my C36 AMG (in which I think is a better built vehicle than my ML320)....No offense to anyone..............lol
hyprr1 is offline
post #4 of 10 (permalink) Old 04-07-2010, 08:34 AM
Date registered: Jan 2007
Vehicle: 1999 ML320 Elegance, BMW R1150RT, SAAB 9-3
Quoted: 5 Post(s)
re; I'm going to Sunoco and filling up with 94 Octane
the only time in the last 30 years when i got bad gas was when i filled up (my motorcycle) with *94* octane from sunoco!
the stuff does not sell in large volumes - stays around much longer - gets old (lose of volatility) and gets the wrong seasonality (my fill up in the fall likely gave me a tank of summer gas despite it being 2 degrees c. my point - go with the 89 octane for maximum freshness.
you likely know this but a clogged fuel filter can strain your fuel pump.... might be worth changing the filter. however if the gas is bad but not impure i'm not sure the filter is impacted. does a fuel filter catch water? i dont think so. bit late now but you could have pulled a 1L sample from your tank and put it in a jar and seen if water separates out. as a minimum i think you should go back to the gas station and get your money back for the bad gas. i would have done this myself but i did not figure out the problem till the spring.
Unhofliche_Gesundheit is offline
post #5 of 10 (permalink) Old 04-07-2010, 08:58 AM
Quoted: 11 Post(s)
Ah, the story on the Altima now makes sense.
Just thinking out loud: Maybe get your regular gas and put an octane boost in it? Never done that, just throwing out there to see if anyone has negative opinion / experience.
lyleswk is offline
post #6 of 10 (permalink) Old 04-07-2010, 09:16 PM
Date registered: Dec 2006
Vehicle: 1999 ML320
I'd just try running it til it's near empty, going to your usual trusted gas station, filling it up, plus a bottle of Techron for good measure, unhook the battery cable for a few seconds, put it back on, start the car, and see how it runs.
Dan P is offline
post #7 of 10 (permalink) Old 04-08-2010, 06:06 AM Thread Starter
hyprr1's Avatar
Quoted: 22 Post(s)
Yes, I'll try that for sure. Hopefully it'll work out ok.
If not, I'm taking it to my trusted mechanic. There really isn't a way for
me to test out a few other culprits (fuel pump, fuel filter, plugs, coil packs, catalytics
etc..............) so it's best for me to just take it to him and hope it's not something
I usually do the repairs to my cars myself, but i'm extremely busy with some home repairs these days..........."I guess, when it rains, it pours"!................lol
Last week it was my differential on my C36 AMG, now it's my rough running ML320!
"Come-on Mercedes", I'm not lovin you lately!.........lol
Thanks to everyones feedback & I'll let you guys know what the results are!
hyprr1 is offline
post #8 of 10 (permalink) Old 04-08-2010, 07:20 AM
mbenz80's Avatar
Date registered: Dec 2009
Vehicle: 1999 ML320
Quoted: 6 Post(s)
I would think that fuel starvation will give you cel by now. You can check your fuel delivery volume by taking off the fuel supply line on your engine at the fuel rail with 19mm open wrench and turn the key on while catching the fuel to a container. If you get 1 qt./liter in less then 30 seconds, and the fuel rail pressure is about 50-55 psi at idle, your fuel filter is fine. I'm still on the small original at 165K miles running fine.
Check your air filter too while you have your hood up.
Bernard
2003 E320 118K miles
1999 ML320 245K miles
2001 ML320 166K miles sold
2003 Lexus GX470 320K miles
1980 280SE W126 EURO 142mph top speed (gone but not forgotten)
mbenz80 is offline
post #9 of 10 (permalink) Old 04-12-2010, 10:42 AM Thread Starter
hyprr1's Avatar
Quoted: 22 Post(s)
Well, I'm getting my truck back tmrw.
Codes came up as mis-firing cyl. 4, 5, 6.
Basically my ML was in dying need of spark plugs and wires replacement.
My mechanic says that the truck is running amazing now and this tune up was long over due.
Original plugs and wires, so maybe now my gas mileage will be better?
$800 (replaced all 12 spark plug wires, 12 spark plugs, fuel filter, air filter).....
Pic. below: just joking, I still love my Mercedes.................
hyprr1 is offline
post #10 of 10 (permalink) Old 04-12-2010, 02:10 PM
chris.sattlegger's Avatar
Date registered: Nov 2007
Vehicle: 2000 ML320
i hope you didn't pay for the 4 spark plug wires that aren't attached to anything. :-)
chris.sattlegger is offline
    ML320 rough idle - dealership can't fix clearchris W163 M-Class 17 04-05-2016 10:28 PM
    Ml320 Rough Start & Dies at Idle rpesnaux W163 M-Class 27 08-03-2010 07:14 AM
    2000 ml320 rough idle dealer wants to charge $1100 luvinlife General Mercedes-Benz 12 08-04-2009 10:05 AM
    200 ml320 rough idle dis614 W163 M-Class 5 06-22-2007 02:47 PM
    2001 ML320 rough idle cea W163 M-Class 1 03-04-2007 11:23 PM
