Removing paneling on A-Pillar Help... - Mercedes-Benz Forum
post #1 of 12 (permalink) Old 03-22-2010, 02:01 PM Thread Starter
Date registered: Apr 2008
Vehicle: 00 ML430 05 ML500
I am trying to remove the A-Pillar on both sides. I have a picture, which shows the sequence in which to remove it. Picture page AR68.30-P-4050GH,
however, I removed the black molding and removed the clip number three in the picture, and I can not remove the pillar. I found this nice thread on the pillars, however I have tried to remove them and they will not buckle. I do not want to break anything. What is underneath the fabric, plastic.
http://www.benzworld.org/forums/w163...-undone-2.html
2005 ML500
2000 ML430
ML430ROCKS is offline
post #2 of 12 (permalink) Old 03-22-2010, 03:13 PM
porschenut's Avatar
Date registered: Aug 2007
Vehicle: 2000 ML55 AMG
I had this problem a few years back. I recall that just like you, I got hung up at the last clip at the top of the trim and didn't want to pull too hard out of fear that I'd break something. If my memory serves me correctly, the metal clip that connects the trim piece to the metal body is shaped in such a way that it resists breaking so long as you pull the part directly away from the pillar. The metal spring clip had a mushroom shaped compression tip that inserted or popped/clipped into a flat metal slot on the A pillar. I remember thinking that I just wasn't pulling hard enough out of fear when you really can apply quite a bit of force without breaking anything. If you pull the trim away from the pillar enough to get your fingers behind it, feel around for the clip. When you get an idea of how it's positioned/located, use the slot that it's inserted into as your focal point and pull the entire trim in a perpendicular direction from the sheet metal pillar (and the slot itself). That motion should allow the mushroom tip to compress as you pull it through and thus release the whole plastic trim piece from the top end first.
Black 2000 ML55 AMG - Bilstein shocks & Eibach springs - H&R anti-sway bars - 22x10.5" TSW Bremma Wheels - 295/30/22 Falken Ziex Tires - Powerchip ECU re-flash http://www.benzworld.org/forums/w163...ml#post2829197
porschenut is offline
post #3 of 12 (permalink) Old 03-22-2010, 03:38 PM
bocabenz's Avatar
Date registered: Jul 2006
Vehicle: 2000 ML430 SOLD, 2007 BMW 328i Coupe, 2014 BMW i3
Don't be scared to put a little muscle into it is what I recall.
bocabenz is offline
post #4 of 12 (permalink) Old 03-23-2010, 05:41 AM Thread Starter
Thank you, I will try it again tonight for sure...
2005 ML500
2000 ML430
post #5 of 12 (permalink) Old 03-23-2010, 05:47 AM
boardboy330's Avatar
Date registered: Mar 2008
Vehicle: 2000 ML320
Quoted: 57 Post(s)
Send a message via AIM to boardboy330 Send a message via Yahoo to boardboy330
Yup...pulled and installed these several times...just sack up and pull lol
When you reinstall...put the metal clips on...and try to get the inner side in before th outer side. When you are installing...youll see what I mean.
"I'd rather peel off my skin and bathe my weeping raw flesh in a bath of vinegar than spend any time with you. But that's just my opinion. Don't take it personally."
(\__/)
(o.O )
(> < ) This is Bunny. Copy Bunny into your signature to help him on his way to world domination
2000 ML320
boardboy330 is offline
post #6 of 12 (permalink) Old 03-23-2010, 08:03 AM Thread Starter
Will do, thank you... So I have to pull away or pull up, or both?
2005 ML500
2000 ML430
post #7 of 12 (permalink) Old 03-23-2010, 08:21 AM
Vehicle: 2000 ML320
Quoted: 57 Post(s)
One clip is in the side...the other in the bottom. I personall grab the peice closest to the door and pull straight down...then slightly twist sideways and pull from the center of the vehicle toward you...just be careful...it is only plastic. Use FIRM pull...not excessive force - hopefully that makes sense.
(\__/)
(o.O )
2000 ML320
post #8 of 12 (permalink) Old 03-23-2010, 10:47 AM Thread Starter
Perfect sense. Thank you !
2005 ML500
2000 ML430
post #9 of 12 (permalink) Old 03-24-2010, 06:52 PM Thread Starter
I took them out, it is hard to break something while trying to take them out. They are hard plastic and very flexible. Thanks for your help !
2005 ML500
2000 ML430
post #10 of 12 (permalink) Old 03-25-2010, 05:34 AM
Vehicle: 2000 ML320
Quoted: 57 Post(s)
I did Alcantara...people stop and look all the time when the windows are down...touch to see what the "fabric" is.
My next mod is having my fiancé's mother embroider the MB Logo down the pillar. Hard to find pics...but I WILL get it done.
(\__/)
(o.O )
2000 ML320
    Removing B-pillar covers (exterior) bhatt W220 S-Class 7 10-28-2014 09:35 AM
    Body Paneling schwalbe181 W201 190-Class 5 01-14-2008 04:34 PM
    HELP! How to reinstall the wood paneling?? bulahee W201 190-Class 2 06-22-2006 09:49 PM
    Removing cloth covered trim from inside of A-Pillar fgwinn W211 E-Class 5 08-14-2005 04:34 PM
    Fat Paneling on later models CharlieCummings W124 E,CE,D,TD Class 0 04-20-2004 03:07 PM
