Oil Hi indicator in ml320 1999 - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 03-05-2010, 12:26 PM Thread Starter
Date registered: Feb 2008
I have checked the dip stick and the oil level is in the middle between high and low but the Oil high indicator still comes on after I have driven for a mile or so. This has happened in the past also after oil change and eventually the oil high indicator goes away after the ml has burned enough oil and the dipstick indicates that the oil level is closer to the low level mark.
Is it ok to have the oil filled closer to the low level mark in dipstick and then refilling a little oil every so often since the ml keeps burning oil? ANy other ideas on this?
deepdubey is offline
post #2 of 3 (permalink) Old 03-14-2010, 08:56 PM
Vehicle: 98 ML 320 100K
Mine done the samething, so I pumped out about 4-6 oz. everything is fine, 2500 miles later it says -2qt oil, checked it was still in the center. I put 8.5 qts in it to start with. So I added 4oz, 4 days later hi oil... I'm still searching to see what I find on here.
bsldallas is offline
post #3 of 3 (permalink) Old 03-15-2010, 02:25 PM
Date registered: Aug 2007
Vehicle: '08 ML320 CDI
Quoted: 33 Post(s)
The dipstick is the indicator I would trust. I received the high warning as well but that was because it was filled up all the way to the max line. I sucked some oil out through the dipstick and was fine after that.
'08 Merc ML320 CDI
'00 Merc ML320 SOLD SEP '14
'07 VW GTI APR stage 1
'08 Triumph Daytona 675 SE
'14 Kawasaki Ninja 1000
'02 996TT
luciano136 is offline
    1999 ML320 vs. 1999 RX300, which is better ? mbeclass W163 M-Class 8 05-15-2015 04:20 AM
    ML320 1999 Oil Sludging warranty repair - $5662 [long saga] NewsHound W163 M-Class 8 05-16-2009 10:47 AM
    99 ML320 - no power sterring and batter indicator light on - Please Help!! miryal W163 M-Class 21 04-29-2009 07:27 PM
    Upgrading ML320 Headlight, Taillight and Mirror Indicator iriaanenih W163 M-Class 1 07-24-2007 07:58 AM
    bottom oil pan gasket drip, 1999 ML320 bpc35c W163 M-Class 3 02-13-2007 05:43 PM
