CEL on ml320 cylinder #5 misfire. Any advice? - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W163 M-Class
Old 01-26-2010, 04:45 PM   #1 (permalink)
Date registered: Jun 2006
Vehicle: 2001 ML 320
Hello,
My car idles rough at a stop light and the check engine light will come on then run rough. It has 110K miles on it.
I took it to Autozone to get the codes checked and it came back with P0305 cylinder misfire detected on cylinder #5.
I replaced all the plugs around 60K miles. Do you think it could be the wires? Can you just buy a single wire or so you have to buy the whole set?
Any other ideas?
Thanks!
zmanzbo is offline   Reply With Quote
Old 01-26-2010, 05:41 PM   #2 (permalink)
Date registered: Aug 2006
Vehicle: 02 ML320
Yes you can buy individual wires at any dealer. Just tell them the year and model and what cylinder.
43sqd is offline   Reply With Quote
Old 01-26-2010, 06:29 PM   #3 (permalink)
Cool thanks. Would that be the best place to start?
Old 01-26-2010, 07:15 PM   #4 (permalink)
Vehicle: 02 ML320
Without a scanner you will be making numerous trips to AutoZone just to see where the problem lies.
What you will have to do is remove the spark plug wires from the spark plugs on cylinder 5. Remove the elec. plug to the coil and then the one bolt holding the coil. Do the same to cylinder #2, and swap them both because both cylinders have the same length wires (see diagram below).
Then you will have to remove the negative battery cable (hopefully you have the radio code) for 1 min. to clear the codes, replace it and then start the engine. Then you will have to make another trip to AutoZone to see where the misfire is. Then post back with the results.
Old 01-26-2010, 08:02 PM   #5 (permalink)
Or should I just buy a single wire from the dealer and install that? Any idea what those go for? I know a full set is ~$200.
Thanks alot for all the info!
Old 01-26-2010, 10:18 PM   #6 (permalink)
Also, do you have any PDF's on a how-to change out the wires?
Thanks.
Old 01-27-2010, 03:28 AM   #7 (permalink)
Vehicle: 02 ML320
There are two wires per cylinder, therefore you will have to buy two. And there is no pdf on changing wires.
Old 01-27-2010, 05:31 AM   #8 (permalink)
Michael Pillay's Avatar
Date registered: Oct 2003
Thanks.
It is pretty straight forward. Just pop the old one of and replace with a new one. If the old one will not come of, use an open end 17 mm wrench to get some leverage.
Mike
Michael Pillay is offline   Reply With Quote
Old 01-27-2010, 08:50 AM   #9 (permalink)
Just called the dealer they want $60 for each wire haha. I will need 2 so $120 for a pair. I can get a whole set online for $199.
Looks like I will be just swapping #5 with #2 tonight.
Thanks to all for the info.
Old 01-27-2010, 09:02 AM   #10 (permalink)
FAR888's Avatar
Date registered: Mar 2007
Vehicle: 2002 ML55 AMG, 1999 C280
Smile
.....Looks like I will be just swapping #5 with #2 tonight....
Hello zmanzbo,
As I understand it, swapping wire #2 with wire #5 is NOT the solution to the problem - It is just a means of ascertaining the root of the problem.
I believe 43sqd advised as he did so as to help you ascertain whether indeed wire #5 was faulty and causing the missfire at cylinder #5.
IF on swapping wire #5 with wire #2 then erasing the existing codes and then having the codes read afresh you obtain a code P0302 (Missfire cylinder 2) you will have established beyond reasonable doubt that it is that particular wire (previously at #5) that is now causing the missfire at cylinder 2.
THEN you must simply purchase ONE wire from the dealer and replace it with the old faulty one.
Good luck!
FAR888 is offline   Reply With Quote
Bookmarks
2000 ML320 #2 cylinder misfire bryinga W163 M-Class 2 01-05-2010 04:58 PM
CEL-cylinder misfire. Looking for opinions. chong188 W202 C-Class 1 12-17-2008 03:24 PM
Misfire cylinder #5 on my 01 ML320 lisamwm04 W163 M-Class 4 07-22-2008 11:08 AM
2003 C230 with CEL and Cylinder Misfire ryanwestman W203 C-Class 5 05-23-2007 06:31 AM
CEL - CODE P0308 - Cylinder 8 Misfire hadam W210 E-Class 3 02-23-2007 10:37 AM
