Removing Tensioner Pulley? - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 09-17-2009, 03:24 PM Thread Starter
Date registered: Mar 2009
Vehicle: 1999 Mercedes ML320
How do you? I have the first piece off. I just have to get the other piece. I don't know the names of it so excuse me. And what tool do I use?
skatewillthee is offline
post #2 of 7 (permalink) Old 09-17-2009, 03:35 PM
Witek_M's Avatar
Date registered: Sep 2008
Quoted: 116 Post(s)
Pulley is not available as separate part. Needs to be replaced along with tensioner.
http://www.benzworld.org/forums/3330704-post29.html
1972 280SEL 4.5
1999 ML320
2000 E320
Witek_M is offline
post #3 of 7 (permalink) Old 09-17-2009, 09:04 PM
pcy
Date registered: Feb 2005
Vehicle: '07 C280 4matic, '06 530i, '98 ML320
Quoted: 2 Post(s)
The following picture should help you in understanding how to remove the tension on the tensioner.
pcy is offline
post #4 of 7 (permalink) Old 09-18-2009, 02:54 AM
Date registered: Aug 2004
thats the updated version....yours may look a lil different...
imwalkin is offline
post #5 of 7 (permalink) Old 09-21-2009, 01:45 PM Thread Starter
Yeah I meant the tensioner as well. And as for the picture that is the part im about to order. I think the tool I need for the one I have on now is a star wrench or something like that. I am guess at the name.
post #6 of 7 (permalink) Old 09-21-2009, 01:57 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
If you're talking about the bolts that hold the tensioner to the engine, those are External Torx. You can buy a good set of them at Sears in the Lisle brand for under $20 with a nifty rubberized holder so they don't rattle around in your toolbox. MB uses lots of those under the hood, so buying the set is worth it.
Check Codes is offline
post #7 of 7 (permalink) Old 09-22-2009, 05:24 PM Thread Starter
Thank you my good man. That is what I need.
    Tensioner pulley/ Idler pulley bearing dimensions? necromancer W124 E,CE,D,TD Class 6 10-13-2010 07:42 PM
    Pulley tensioner replacement ? Eirik 400 SE W140 S-Class 6 02-27-2008 01:38 PM
    Tensioner pulley Bazzle R170 SLK-Class 9 02-12-2007 04:27 PM
    belt tensioner/pulley Rishi C208/A208 CLK-Class 2 10-23-2006 02:00 PM
    C230 tensioner pulley dmar836 W202 C-Class 0 01-26-2005 09:38 PM
