Transmission Flush vs. Drain and Fill - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 08-13-2009, 12:47 PM Thread Starter
JCM1's Avatar
Date registered: Jun 2008
Vehicle: 2013 E350, 2005 ML500, 2005 C230K, 1980 450SL, 1996 S600 Coupe
Question Transmission Flush vs. Drain and Fill
I am planning to change the transmission fluid and axle fluid on my 05' ML500. I spoke to the dealer and was told they usually flush the transmissions. I was under the impression that you cannot flush the trans on the ML's. Also I have avoided flushes like the plague due to a bad experience as well as stories of bad experiences. They are willing to do a drain and fill but are not recommending it due to the fluid in the torque converter and trans cooler not being replaced. I have the extended warranty and want to make sure I am current with the recommended service. What has everyone else done when it comes to transmission fluid replacement? Also what do you recommend as the mileage/age for replacement? (I am not towing or off-roading) Any advice would be greatly appreciated.
JCM1 is offline
post #2 of 8 (permalink) Old 08-13-2009, 01:44 PM
Will Moderate For Cigars
cmitch's Avatar
Date registered: Apr 2005
Vehicle: 2002 ML320, 2005 S430 4MATIC, 2010 F150 Crew Cab
Quoted: 216 Post(s)
I'm uneasy about flushes. It stirs up trash. I would drop the pan, replace the filter, pan gasket and refill. That will take about 3 1/2 to 4 liters.
2005 S430 4Matic 'Morton' W220.183 • 722.671 Rest in Peace
Bells and whistles are thorns and thistles.
cmitch is offline
post #3 of 8 (permalink) Old 08-13-2009, 02:08 PM
Date registered: Jul 2006
Vehicle: 1999 E55, 2001 E320, 1990 560 SEC, 2004 ML350, 2001 ML55, 1995 S500, 1998 SL500, 2010 E550 Sport zoo
Quoted: 131 Post(s)
I don't recommend flushing either - and I don't know a MB dealer that does.
The MB "service" is dropping the pan, and replacing filter, then re-up on the fluid.
Keep the beat !
fabbrisd1 is offline
post #4 of 8 (permalink) Old 08-13-2009, 02:14 PM
Date registered: May 2008
Vehicle: '99 ML430 and '01 SLK320
Agreed, my indy suggested the same thing drop the pan, change filter and gasket and top off.
marcin411 is offline
post #5 of 8 (permalink) Old 08-14-2009, 07:58 AM Thread Starter
JCM1's Avatar
The drain and fill seems to be the general consensus from the information that I have found and the responses so far to my post. This reaffirms my anti-flush stance for transmissions. I'll have the dealer do the drain and fill. I currently have a little over 50,000 miles. Is this too soon for a fluid change?
JCM1 is offline
post #6 of 8 (permalink) Old 08-14-2009, 08:05 AM
Good question, I'm sure you will get a thousand opinions as well. It all depends on how you drive, where you drive, and your particular transmission. I don't think anyone has the secret formula. I can tell you I did mine at 100K and I've never had any trany issues, knock on wood.
post #7 of 8 (permalink) Old 08-14-2009, 09:41 AM
Kajtek1's Avatar
Quoted: 1226 Post(s)
I did flush on my E and it work very well, but I had no problems before even the car had 215k on it and I did drop the pan before flush.
I can understand why flush is "recommended" by lot of shops. You just disconnect a transmission cooling lane, hook up the fast connectors and push the button on the machine making big money on 15 quarts of expensive fluid having clean hands.
Sure beats getting fluid into your sleeves while dropping the pan and than only to collect for 3.5 quarts of fluid, even no more than 3 goes there.
Per my conclusion wiping the pan off from heavy residues is the critical part of the service. You can read my conclusions in "My take ..... " in General section.
Kajtek1 is offline
post #8 of 8 (permalink) Old 08-19-2009, 01:11 PM Thread Starter
JCM1's Avatar
The convenience of flushes makes sense. My concern is that flushes will stir up debris on the bottom of the pan and in the filter. I understand the issue of not being able to drain the torque converter or cooler when doing a drain and fill. I still prefer the drain and fill just from the standpoint of being able to replace the filter and look at the type of debris on the bottom of the pan and overall condition of the fluid. Is there a way to check the condition of the fluid without dropping the pan first? My understanding is the "dipstick tube" is not the same as most other vehicles.
JCM1 is offline
    Transmission Drain and Fill - ML430 PhiSig W163 M-Class 5 02-25-2009 03:03 PM
    Anyone use the 'Prestone Flush and Fill Kit' when doing a flush? benztech123 W123 E,CE,D,CD,TD,TE Class 2 11-16-2008 05:16 PM
    Transmission flush or drain and refill patsslk R170 SLK-Class 14 09-17-2007 10:04 PM
    722.6 transmission Flush (TC w/o drain plug) a DIY? Benzguy888 W211 E-Class 6 06-13-2007 02:15 PM
    Transmission Flush and Fill jinsoojoo W203 C-Class 2 08-24-2005 07:33 PM
