» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W163 M-Class
Old 07-03-2009, 05:05 PM   #1 (permalink)
Date registered: Jul 2009
ML320 Issues, Need Help
Need some advice on a couple of issues I am having with my 2000 ML 320:
1. The aux fan fuse is blown, how hard is this to replace, can I fix it on my own (i am a novice)?
2. My engine has a rough idle and makes a loud click noise when the hood is up. Idle is not bad when in neutral. Somewhat worse when the a/c is on.
I just got it back from the shop for having an engine sensor fixed, the dealership claimed that may fix the idle problem (big suprise, it didnt). The dealer also said it may be my choice of fuel. Anyway, would a fuel additive help or an injection cleaner or gumout products? Thanks for any help on these issues. I appreciate it.
stevhuff is offline   Reply With Quote
Old 07-03-2009, 06:27 PM   #2 (permalink)
Michael Pillay's Avatar
Date registered: Oct 2003
Vehicle: w126, w163, R170
Have you been using a grade other than premium? Was it the engine sensor mentioned the Mass Air Flow sensor?
Mike
1990 Mercedes Benz 300 SEL
2001 Mercedes Benz ML320
1999 Mercedes Benz SLK230
1986 Porsche 911 Carrera
Michael Pillay is online now   Reply With Quote
Old 07-03-2009, 08:29 PM   #3 (permalink)
Thanks for the reply. I only have put prem gas in my ml. They did not mention specifically which engine sensor I had replaced. It died on me and would not turn over to fully start.
Old 07-03-2009, 08:46 PM   #4 (permalink)
It is listed as a position sensor, not the MAF sensor.
Old 07-04-2009, 05:17 AM   #5 (permalink)
Date registered: Aug 2006
Vehicle: 02 ML320
Novice or not, it shouldn't be too difficult to locate where the clicking noise is coming from. Take a photo of it and post it so we can help you.
As for the position sensor, they probably replaced the Throttle Positon sensor, but again, novice or not, you didn't even ask to be shown what part was replaced? Look on your bill and see what the part number was replaced.
43sqd is offline   Reply With Quote
Old 07-04-2009, 06:22 AM   #6 (permalink)
It was the crank sensor. 003-153-28-28. You are right I should have gone back to the dealer that day but I let work get in the way. Thanks for the help.
Old 07-04-2009, 07:28 AM   #7 (permalink)
Is the aux fan fuse easy to replace and is it an easy part to find?
Old 07-04-2009, 08:54 AM   #8 (permalink)
Witek_M's Avatar
Date registered: Sep 2008
Page 186 in Owners Manual. Bottom of fuse box cover has legend, spare fuses and removal tool.
1972 280SEL 4.5
1999 ML320
2000 E320
Witek_M is offline   Reply With Quote
Old 07-04-2009, 01:57 PM   #9 (permalink)
Thanks for the help. Who sells fuses? Advance auto parts?
Old 07-04-2009, 02:38 PM   #10 (permalink)
never mind, found extra fuse.
Couple issues with my '98 ML320 slayblack W163 M-Class 3 06-29-2009 11:26 PM
ML320 idle in drive issues! tfent New Member Introductions 0 01-07-2009 07:59 AM
ML320 trans issues baisdelr W163 M-Class 7 02-24-2008 12:37 PM
1998 ML320 Issues yusufyila W163 M-Class 1 10-06-2006 11:26 AM
"01 ML320 issues with A/C CaliBNZ W163 M-Class 14 08-27-2002 04:07 PM
