» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W163 M-Class
Old 06-30-2009, 09:36 AM   #1 (permalink)
Date registered: Jun 2009
Vehicle: 1999 ML320
Driver side window wont close.... motor or switch???
Hi- My driver side front window has been slow for the past few days. At first I thought it was the switch, so I took it out and followed the instruction on how to fix it, but with no success. I'm starting to think it's the motor now. The window goes down fine but not up. Any suggestions? Is it the motor or the window? Is it difficult to take the door panel off to replace the motor? It's down now, and I hate having to cover it with a plastic bag! Thanks.
Eric102 is offline   Reply With Quote
Old 06-30-2009, 10:16 AM   #2 (permalink)
Witek_M's Avatar
Date registered: Sep 2008
Why motor? Switch reverses polarity of current going to the motor to make it turn one way or the other. If it goes one way then motor is fine. Replace switch group and then check current consumption.
Please, update your profile with model, production date and location.
1972 280SEL 4.5
1999 ML320
2000 E320
Witek_M is offline   Reply With Quote
Old 06-30-2009, 10:25 AM   #3 (permalink)
FAR888's Avatar
Date registered: Mar 2007
Vehicle: '02 ML55 AMG
Send a message via Yahoo to FAR888
Indulge me Witek.
Isn't it possible the motor has become weak and is okay when coming down, with the help of gravity, but not so strong when trying to raise the window?
FAR888 is offline   Reply With Quote
Old 06-30-2009, 10:49 AM   #4 (permalink)
Vehicle: 1999 ML320
That's what I thought aswell, but in any event, I ordered a new switch...
Old 06-30-2009, 10:57 AM   #5 (permalink)
FAR888's Avatar
Eric, please let us know, after installation, whether that solves the problem or not.
Good luck!
Old 06-30-2009, 11:03 AM   #6 (permalink)
Witek_M's Avatar
Window regulator has helper spring that offsets gravity and keeps things tight and rattle free.
Below is method for checking motor current consumption.
Old 07-02-2009, 06:28 PM   #7 (permalink)
oreif's Avatar
Vehicle: '00 w163 55 amg '02 w208 55 amg
Send a message via MSN to oreif
just did driver window switch with my oil change. left starbucks mon & window going up was a 'no go' my indy turned the key and manipulated the switch to get it up until the repair yesterday. part #1638206610 for $157 per invoice. good now.
oreif is offline   Reply With Quote
Old 07-02-2009, 11:14 PM   #8 (permalink)
macdrone's Avatar
Date registered: Nov 2006
Vehicle: 1993 400E 222111 miles "Gunter", 1999 ML320 187000 miles "Fizgig"
what part is that?
macdrone is offline   Reply With Quote
Old 07-03-2009, 12:34 AM   #9 (permalink)
pcy
Date registered: Feb 2005
Vehicle: '98 ML320, '97 328i
oreif, very likely, the windows 'switch assembly' is replaced on your truck.
pcy is offline   Reply With Quote
Old 07-04-2009, 04:04 PM   #10 (permalink)
macdrone's Avatar
My window is coming up at a slight angle would that be the regulator? Seems kind of slow but like its grabbing in the front. I lubed it up with litium grease I had and didnt change anything. The inner part of the door that the regulator is riveted to flexes quite a bit going up or down like its working pretty hard. It doesnt always seal at the backside as I can hear air as I go down the highway and have to push the window backto stop it.
2000 ML 320 driver side window switch NCarr W163 M-Class 12 06-09-2009 10:52 PM
FS: Window motor front left side driver side alvaro260e88 For Sale, Trade & Wanted Items 0 08-29-2006 03:49 PM
Rear driver side window wont go up!!! Court W140 S-Class 2 11-06-2003 08:43 PM
Help!! Driver side window won't close (go up)! =( G-Benz W163 M-Class 5 10-19-2003 01:04 AM
Broken driver side window motor fastbenz W208 CLK Class 1 08-14-2003 01:18 PM
