ML320 Engine Cover - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 06-08-2009, 11:29 AM Thread Starter
Date registered: Apr 2009
Vehicle: mercedes Benz ML320
Question ML320 Engine Cover
I have a ML320. I was able to change the oil and replace the seals on the oil filter, saving the US$100 from the shop.
My owners manual does not clearly describe where the power steering fluid goes in at. I think it is the black knob at the front which is partially blocked by the engine cover.
Now, I've been trying to get this black plastic engine cover off the top, but I can't fine where or how it is released.
pls help.
kbhowmed is offline
post #2 of 11 (permalink) Old 06-08-2009, 11:43 AM
Will Moderate For Cigars
cmitch's Avatar
Date registered: Apr 2005
Vehicle: 2002 ML320, 2005 S430 4MATIC, 2010 F150 Crew Cab
Quoted: 210 Post(s)
It lifts up from the front and unsnaps. Quite easy to remove.
2005 S430 4Matic 'Morton' W220.183 • 722.671 Rest in Peace
Bells and whistles are thorns and thistles.
cmitch is offline
post #3 of 11 (permalink) Old 06-08-2009, 11:50 AM Thread Starter
Just Pull it
OK. cmitch. So I guess that I just grab the front of it and pull it up?
Have you ever done any engine cleaning?
thnx
kbhowmed is offline
post #4 of 11 (permalink) Old 06-08-2009, 12:26 PM
Date registered: Jul 2006
Vehicle: 1999 E55, 2001 E320, 1990 560 SEC, 2004 ML350, 2001 ML55, 1995 S500, 1998 SL500, 2010 E550 Sport zoo
Quoted: 127 Post(s)
Best to do engine cleaning with the cover up/off, but with engine running so you can back off if the water starts givings you misfires. With a high pressure car wash wand, with high pressure water should clean up zip-sip, get the area behind the power steering reservoir so that later you can check if the seepage there is from oil fills dripping down from the oil fill cap, or if you have seepage from a leaking o-ring on the power steering reservoir.
fabbrisd1 is offline
post #5 of 11 (permalink) Old 06-08-2009, 01:45 PM
cmitch's Avatar
Quoted: 210 Post(s)
I, personally, wouldn't spray water on the engine unless I covered the alternator first.
cmitch is offline
post #6 of 11 (permalink) Old 06-08-2009, 03:17 PM Thread Starter
Lightbulb Spark plugs too
OK. speaking of covering the alternator, I guess you would also cover the spark plugs too, huh?
And can anyone verify which cap is the power steering. I know the brake reservoir is the one in back because it has writing on it.
thnx for all help.
kbhowmed is offline
post #7 of 11 (permalink) Old 06-08-2009, 04:16 PM
cmitch's Avatar
Quoted: 210 Post(s)
thnx for all help.
VVVVV
Name:	ML Engine.jpg
cmitch is offline
post #8 of 11 (permalink) Old 06-11-2009, 06:34 PM Thread Starter
Talking great pic
cmitch,
I got to give much kudos for that great pic. That made all the suggestions practical.
thnx.
kbhowmed is offline
post #9 of 11 (permalink) Old 06-11-2009, 07:55 PM
Darkmann's Avatar
Vehicle: 05 500
Quoted: 35 Post(s)
Yes, I forgot to mention that though I don't cover the alternator, I don't douse it with H2O, I do rinse the alternator out. I have done this for all my Nissans, my E, the MLs, my Bimmer and even my VW and none of them have died yet. The Nissans, I can start right away with no issues. The Germans, I usually wait a while, but not tens of minutes. So far I have had no issues at all. The key is not to use high pressure because that may penetrate the seals on the plugs and that would result in issues.
1996 Z32 TT
A 18Hp lawn mower
370Z - I want one!
Darkmann is offline
post #10 of 11 (permalink) Old 06-11-2009, 07:59 PM
Darkmann's Avatar
Vehicle: 05 500
Quoted: 35 Post(s)
You may be right, but I have never done it with motor running - messy anyway. I usually do it with motor off and cold and not high pressure. The one time I tried HP on my E, I had problems - the cooling fan shorted out and stayed on until MB roadside advised me on what to do. I still say use some kind of non corrosive degreaser and, stay with low pressure and motor off.
1996 Z32 TT
A 18Hp lawn mower
370Z - I want one!
Darkmann is offline
    WTB: Front bumper cover for 98 ML320 Number400 For Sale/Wanted/Trade/Giveaway 0 01-10-2006 08:38 AM
    WTB CD changer cover for ML320 rgbmanse For Sale/Wanted/Trade/Giveaway 0 08-01-2005 03:23 PM
    ML320 cover???? chona W163 M-Class 9 07-20-2004 10:34 AM
    will the AMG ML55 engine cover fit into the 03' E500 engine? MB E500 W211 E-Class 2 10-16-2002 10:59 PM
    Sport bumper cover for 2000 ML320 Telvis W163 M-Class 7 06-22-2001 01:46 PM
