Fuel gauge problem - Page 3 - Mercedes-Benz Forum
post #21 of 77 (permalink) Old 10-13-2011, 03:57 PM
Date registered: Dec 2009
Vehicle: 1996 E320 & 2003 ML320
I have an 03 with the same fuel gauge issue. Has anyone had success using the# 5 fuse trick or is there something else I need to do to fix this on the 03?
Ed
triguy450 is offline
post #22 of 77 (permalink) Old 10-13-2011, 05:18 PM
mbenz80's Avatar
Vehicle: 1999 ML320
Quoted: 6 Post(s)
Mine is working perfect now, that is because I had to replace the fuel pump assembly.
When I checked the old pump, contacts on sending unit were dirty, coated with soot.
2003 E320 118K miles
1999 ML320 245K miles
2001 ML320 166K miles sold
2003 Lexus GX470 320K miles
1980 280SE W126 EURO 142mph top speed (gone but not forgotten)
mbenz80 is offline
post #23 of 77 (permalink) Old 10-13-2011, 05:29 PM
megadamp's Avatar
Date registered: May 2008
Vehicle: 1999 ML320
Quoted: 69 Post(s)
Bernard do you think it would work if you cleaned it and put it back?.
megadamp is offline
post #24 of 77 (permalink) Old 10-13-2011, 06:38 PM
mbenz80's Avatar
Vehicle: 1999 ML320
Quoted: 6 Post(s)
Fuel pump update - open hart surgery
Yes, it will.
But a bit of work have to be done to take the pump out.
I actually did that and put it back together but two days later my low fuel pressure problem came back, I could only do 35mph maximum. Sending unit and primary fuel filter built into pump are in first picture.
Here is my old fuel pump after cleaning, last picture is Pierburg fuel pump motor with bad (worn out) carbon brushes.
ID:	403386   Click image for larger version
ID:	403387   Click image for larger version
ID:	403388   Click image for larger version
mbenz80 is offline
post #25 of 77 (permalink) Old 10-13-2011, 06:48 PM
Date registered: Jul 2006
Vehicle: 1999 E55, 2001 E320, 1990 560 SEC, 2004 ML350, 2001 ML55, 1995 S500, 1998 SL500, 2010 E550 Sport zoo
Quoted: 127 Post(s)
Fuel pump issue to the side for the moment, fuel sensor issues in the tank can often be recoevered using Stabil Blue (Marine Formula) in two tanks of gas over a 500 mile or so interval, the Stabil cleans up the fuel sensor in the tank... actually really good for that specific issue as well as prevents that specific issue.
fabbrisd1 is offline
post #26 of 77 (permalink) Old 12-21-2011, 04:12 PM
Riqv's Avatar
Date registered: Oct 2009
Vehicle: 2000 ML55 AMG
Does anyone know where exactly Fuse #5 is in the RSE2 Fuse holder for a 2k ML55?
Riqv is offline
post #27 of 77 (permalink) Old 12-22-2011, 02:06 AM
Date registered: Aug 2006
Vehicle: 02 ML320 06 ML500
Quoted: 909 Post(s)
Here it is.
43sqd is offline
post #28 of 77 (permalink) Old 12-22-2011, 02:42 PM
Riqv's Avatar
yet again 43sqd, thank you!
Riqv is offline
post #29 of 77 (permalink) Old 06-06-2012, 04:54 PM
Date registered: Jun 2012
Quoted: 2 Post(s)
Hi:
I have a 2002 ML320, which has been experiencing the symptoms of the faulty fuel gauge.
I tried the workaround of unplugging the fuse.
When unplugged the fuel needle (and other controls) continued to show levels. They did not "fall to zero" like when you turn the car off. What DID happen is that the car would not turn on. The ignition worked but then it seemed as if the fuel pump was off because it would not start.
Is this what is supposed to happen when unplugging the correct fuse for the workaround?
After unplugging and reinserting the fuse, the car of course worked normally, but I did not see any material difference with the behavior of the fuel gauge.
Does that mean that the only solution is to change the sender (with fuel pump)?
Thanks
Izwebusr is offline
post #30 of 77 (permalink) Old 06-06-2012, 06:03 PM
megadamp's Avatar
Vehicle: 1999 ML320
Quoted: 69 Post(s)
My fuel gauge is at times a little off. But what surprised me was if i use texaco fuel which in the uk is owned by chevron, may be wrong but i think i am right, contains techron as a fuel additive. If i fill my tank my fuel gauge starts working better without a shadow, and it does not take long. The expense kills me though.
megadamp is offline
    The Ultimate Solution to the Fuel Gauge/Fuel Sending Unit Problem jengel111 W163 M-Class 4 03-10-2013 12:22 PM
    Fuel Gauge Problem BobGreenfield R170 SLK-Class 4 11-27-2007 10:04 AM
    Update on Fuel Gauge Problem: Got Fuel Pump Replaced Today tjhsiao W163 M-Class 4 10-25-2002 05:47 PM
    Fuel gauge problem Guest (MBNZ) R129 SL-Class 3 07-25-2002 07:42 AM
    Anyone with fuel gauge problem? Guest (MBNZ) W203 C-Class 2 11-04-2001 10:18 PM
