Electric folding exterior right mirror Does Not Engage in Correct Stop Position - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 11-19-2008, 01:21 AM Thread Starter
Date registered: Nov 2008
Hi,
I have a ML270 2002 and someone hit into my passenger side mirror. Now when I press the button to fold the mirror, it folds in more than the drivers side one and makes a horrible clicking sound when folding.
Electric folding exterior right mirror Does Not Engage in Correct Stop Position.
Please can some advise on how to fix and whether anyone has any pictures to illustrate how to fix?
Thanks.
Regards
mboy977 is offline
post #2 of 9 (permalink) Old 11-19-2008, 11:54 AM
00 ML430 Bulldog's Avatar
Date registered: Mar 2003
Vehicle: 2000 ML430
Originally Posted by mboy977 View Post
Hi,
Thanks.
Regards
hold the mirror fold button in.The mirrors will fold in and resynchronize. You will hear the clicking noise during the resync. Hold the mirror fold button in until the clicking stops. That will fix it
ONE TUFF LOOKING ML!!!
00 ML430 Bulldog is offline
post #3 of 9 (permalink) Old 11-19-2008, 02:10 PM Thread Starter
Hi,
Thanks for the advice, I pressed the button until the clicking stopped, but when I opened the mirrors and closed it again the clicking is still coming from the passenger side. I guess something has been damaged inside.
Regards,
mboy977 is offline
post #4 of 9 (permalink) Old 11-19-2008, 02:25 PM Thread Starter
Hi,
I am suprised that it is not easily fixed because the only problem is that the passenger side mirror folds in a little bit more and is making a clicking sound, apart from that the mirror opens and closes perfectly.
mboy977 is offline
post #5 of 9 (permalink) Old 11-19-2008, 06:12 PM
Vehicle: 1990 190E 2.6,.... 1998 ML320, 2005 ML500SE
Quoted: 65 Post(s)
There are re-sync procedures in your manual. They are different depending on weather the mirrors were forcibly folded forward or rearward.
Mike
Mike's ML is offline
post #6 of 9 (permalink) Old 11-20-2008, 03:28 AM
Vehicle: 2000 ML430
Hi,
Regards,
Ok push and hold the button in the open position. The mirrors will attemp to re sync in the open position. you will hear the clicking noise again. hold the button in the open mirrors position until the clicking stops. If it does not work the mirror might be broken indeed.
post #7 of 9 (permalink) Old 11-20-2008, 02:30 PM Thread Starter
Hi,
I try that but the passenger side mirror still folds in more and makes the clicking sound. If I press the closing button again just about when it is going to close then the mirror stops and I avoid the horrible clicking sound.
Thanks for all your help and advise. I guess I going to have to replace the whole mirror.
Regards,
mboy977 is offline
post #8 of 9 (permalink) Old 11-20-2008, 02:38 PM
television's Avatar
Date registered: Sep 2005
Vehicle: 216 with everything. 2002 SL500 with everything. 2009 SL500 with everything.
Quoted: 148 Post(s)
We meet again
Malcolm
"I thought my vasectomy would keep my wife from getting pregnant but apparently it just changes the color of the baby."
television is offline
post #9 of 9 (permalink) Old 11-20-2008, 03:15 PM Thread Starter
Hi,
I have checked the manual and it has no information about re-setting the mirrors. I have tried holding the button down in the close and then in the open position, but the clicking sound on the passenger side still occurs. I can only conclude that I will have to replace the mirror, I went to the dealers and they are charging £525 for the inner mechanics part.
Regards,
mboy977 is offline
    Electric folding mirror fault?? iimms W203 C-Class 10 07-09-2013 04:09 AM
    auto. trans. doesn't engage after stop -- low fluid? holthoff W123 E,CE,D,CD,TD,TE Class 2 03-04-2007 12:33 PM
    electric exterior mirror question 420 SE W126 S,SE,SEC,SEL,SD,SDL Class 5 09-22-2005 05:05 AM
    Adding Folding Exterior mirrors? aquascape R171 SLK-Class 5 05-31-2005 10:02 AM
    Folding exterior mirrors... MikeT W163 M-Class 3 11-16-2001 02:39 PM
