Power Steering - O-ring Replacement - Help! - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 10-30-2008, 10:48 PM Thread Starter
Date registered: Oct 2008
Vehicle: '03 ML320
Hi. I have a 2003 ML320. I just noticed that power steering fluid was on the floor of my garage. After reading through the many posts on here, I decided to investigate. I have pinpoint the problem to be the O-ring. I bought the O-ring and I have found the post for the O-ring replacement instructions from this website (THANK YOU!)....
but the big problem is: What do you use to remove the one retaining bolt? I tried a plier and then a wrench but none would work. Is there a specific tool? If so where can I buy it?
The dealer wants $250 to replace the O-ring for me!!!!! I bought the O-ring ($2.50) and MB PS ($7.45) already...
Please give me advice! Thank you!
bkmyway is offline
post #2 of 8 (permalink) Old 10-30-2008, 11:30 PM
Date registered: Apr 2008
Vehicle: 1999 MTrash 430, its a joke
The retaining bolt? The only bolt that holds the reservoir on is a torx. Are you talknig about the reatiner clip on the rear of the reservoir?
drewbush is offline
post #3 of 8 (permalink) Old 10-30-2008, 11:33 PM
Just saw your other post, T10 torx socket.
drewbush is offline
post #4 of 8 (permalink) Old 10-31-2008, 10:01 AM Thread Starter
Vehicle: '03 ML320
THANK YOU SOOOOOOOOO MUCH! I was losing sleep over this little bolt. Thanks again. I will now go search for that T10 Torx Socket!
bkmyway is offline
post #5 of 8 (permalink) Old 10-31-2008, 11:03 AM
pcy
Date registered: Feb 2005
Vehicle: '07 C280 4matic, '06 530i, '98 ML320
Quoted: 2 Post(s)
Just buy a good set of TORX sockets. You will need various size sockets for other DIY projects.
pcy is offline
post #6 of 8 (permalink) Old 10-31-2008, 01:05 PM
Witek_M's Avatar
Date registered: Sep 2008
Quoted: 107 Post(s)
You need E10 torx. E stands for external/female.
FLE100A, Socket, Shallow, TORX, E10
1972 280SEL 4.5
1999 ML320
2000 E320
Witek_M is offline
post #7 of 8 (permalink) Old 10-31-2008, 05:00 PM
Date registered: Jul 2006
Vehicle: 1999 E55, 2001 E320, 1990 560 SEC, 2004 ML350, 2001 ML55, 1995 S500, 1998 SL500, 2010 E550 Sport zoo
Quoted: 127 Post(s)
Please make a note...
When you replace the existing reservoir, best to replace the reservoir as well. MB delaer price about USD$40. Full dealer parts: new reservoir, o-ring, c-clip, and (2) bottle MB steering oil.
The air thru the system has already blown out a small nylon screen in your existing reservoir.
Your will need #10 torx, a screwdriver (to pop the c-clip), and best a "turkey baster" (to remove the old fluid), and a flashlight.
You also need a jack, and jack stands: which are used in the CRITICAL part of the process which is to bleed the system (WITHOUT THE ENGINE ON - ENGINE OFF PERIOD before your finish up) with the front in the air, turning lock-to-lock to bleed the air and air bubbles in the system.
Do a forum search and you will find in the past 2 weeks there has been one of our members, follwing this process all the way thru - that was TOTALLY successul in eliminating the the leak and eliminating ALL the steering noice.
Good luck !.
fabbrisd1 is offline
post #8 of 8 (permalink) Old 11-01-2008, 02:54 PM Thread Starter
Vehicle: '03 ML320
Hi thank you for your suggestion.
However, right now, I do not hear any steering noise problem...just leaking that I'm sure is the O-ring...so please give me your suggestion on this matter...should I go all out or just fix the o-ring for now and see what happens after?
BTW I just got this car...would someone please tell me some successful stories about their MLs as I am already getting a bit frustrated with this buy.
bkmyway is offline
    Power steering reservoir O-ring Jexpert W163 M-Class 24 12-13-2013 05:26 PM
    Need DIY info on Power Steering reservoir replacement Papabrox W163 M-Class 8 12-20-2007 08:53 PM
    Power Steering Pump Replacement Starglider W220 S-Class 5 03-08-2007 07:07 AM
    Steering Maintenance and O-ring? old slug W123 E,CE,D,CD,TD,TE Class 1 11-19-2006 07:13 PM
    Power Steering Pump replacement help Mayor Bloom W210 E-Class 2 08-25-2005 01:24 AM
