part number for front passenger door actuator - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 10-10-2008, 09:54 AM Thread Starter
dazyp's Avatar
Date registered: Oct 2008
Vehicle: mercedes ml 270
my central locking on the front passenger door is not working , i have took the door panel off and checked the wiring .
i have 12 volts when i lock and unlock the door on the wiring loom for the door lock assembley , which seems to be ok.
i have read other threads about problems with the actuator / solenoid and would assume this is the problem.
i have tried to remove the whole locking assembley by removing the torx screws from the side of the door and then lowering the whole assembley down , but when i get to the bottomi can not physically get it out of the door it catches on the door support ?
my question is , is the actuator and the solenoid the same ? part numbers for these items and any help on removing the lock assembley.
my vehicle is a mercedes ml270 on a 02 plate
dazyp is offline
post #2 of 3 (permalink) Old 10-10-2008, 11:25 AM
Date registered: Aug 2006
Vehicle: 02 ML320 06 ML500
Quoted: 964 Post(s)
Here are the instructions. As for the door lock actuator, there are two dependi8ng on your vin#, so it would be best buying it at the dealer.
http://www.benzworld.org/forums/w163...r-machine.html
43sqd is offline
post #3 of 3 (permalink) Old 10-10-2008, 11:50 AM Thread Starter
dazyp's Avatar
thanks for the link .
i think that must be the most detailed fix i have ever seen , but excellent work for posting it
dazyp is offline
300d gas door actuator part number question P4olom W123 E,CE,D,CD,TD,TE Class 1 08-31-2008 12:43 PM
Door Lock Actuator Part Numbers TheOgre W163 M-Class 1 01-10-2008 04:11 PM
Selling factory Disc changer and passenger door lock actuator silverstreak W163 M-Class 4 01-17-2007 02:59 PM
need actuator part number termite G-Class 2 08-02-2005 04:29 AM
Part number for footwell vent flap actuator???? Evan W203 C-Class 4 03-29-2005 06:17 PM
