ML320 Warning Lights ? - Mercedes-Benz Forum
post #1 of 15 (permalink) Old 09-24-2008, 01:13 PM Thread Starter
BenzMl320J's Avatar
Date registered: Sep 2008
Vehicle: ML320 2002
Post ML320 Warning Lights ?
Hi,
I have a ML320 2002. I've noticed on the dashboard there are 2 warning lights, BAS/ESP and CHECK ENGINE, before i also had one for OIL CHANGE but that has been done and the light is off, but the other 2 no.
I was wondering if i should take the car to my mechanic or dealer so they can scan the car with the computer and tell me what else is wrong, should i and how much would that cost ???
Thanks,
J.
BenzMl320J is offline
post #2 of 15 (permalink) Old 09-24-2008, 01:34 PM
~BANNED~
pointman's Avatar
Date registered: Sep 2003
hahaha
pointman is offline
post #3 of 15 (permalink) Old 09-24-2008, 01:54 PM
falconnian's Avatar
Date registered: Dec 2007
Vehicle: BMW 2007 X3 3.0si, 1999 ML 320 -Sold-
Originally Posted by BenzMl320J View Post
Hi,
Thanks,
J.
you could goto your local pep boys/autozone/etc and pick up a ODB II reader and look the code up yourself. it depends how technical you are. but the problem looks like there might be something wrong with your stability/brake assist. i would advise that you make that a high priority on your list.
falconnian is offline
post #4 of 15 (permalink) Old 09-24-2008, 04:29 PM
bocabenz's Avatar
Date registered: Jul 2006
Vehicle: 2000 ML430 SOLD, 2007 BMW 328i Coupe, 2014 BMW i3
Of course! I don't see why you wouldn't want to get it checked out. Either buy a scanner or go to the dealer. I don't really see what other options you have.
There's no cheap way to ignore a problem.
bocabenz is offline
post #5 of 15 (permalink) Old 09-26-2008, 02:50 PM
Date registered: Sep 2007
Vehicle: ML 270 CDI AUTO 2000
just a quick note......
check the brake light switch.....
it cost very little and is worth changing to cancel it out....
ive just done it and it cos me £10 from MB.....(trade price)
hope it helps...... and its easy to fit..... two screws and two block conectors and a push and twist B/L switch....easy...
its a common fault so im told....
tony.t. is offline
post #6 of 15 (permalink) Old 09-27-2008, 07:05 PM Thread Starter
BenzMl320J's Avatar
Vehicle: ML320 2002
Hi All,
Thanks for all the tips.
My ML320 got all fixed. The 2 front brakes were almost gone so i did replaced them asap.
And the steering wheel was quite loose going to the right so thats also fixed.
The oil change was also done so im quite set for safe drive
I have this car for 2 years how long do they last with a proper mainteance ???
Cheers !
post #7 of 15 (permalink) Old 09-29-2008, 04:28 AM
pcy
Date registered: Feb 2005
Vehicle: '07 C280 4matic, '06 530i, '98 ML320
Quoted: 2 Post(s)
Benzml320, what part did you replace to fix BAS/ESP light?
How did the dealer fix "loose" steering? If you look at the dealer receipt, you may find the answers to these questions...
pcy is offline
post #8 of 15 (permalink) Old 09-29-2008, 10:37 AM Thread Starter
BenzMl320J's Avatar
Vehicle: ML320 2002
pcy,
for BAS/ESP the 2 front brakes were replaced...
i did not go to dealer, i usually go to my private mechanic since i find dealers too expensive and most of the time they rip you off...
post #9 of 15 (permalink) Old 10-01-2008, 07:24 AM
pcy
Quoted: 2 Post(s)
BanzMl320j, I didn't know that BAS/ESP lights would be gone by replacing brake pads.
Or did you mean to type "brake pads light"? If so, that makes sense.
To answer your other question (above)...
These trucks can go well above 200K miles if properly maintained.
pcy is offline
post #10 of 15 (permalink) Old 10-01-2008, 09:20 AM Thread Starter
BenzMl320J's Avatar
Vehicle: ML320 2002
Sorry thats what i meant...
Do you think if i maintain my ML320 well it will last me another few years ??
    ML320 stalls without warning - no codes RaviA W163 M-Class 34 09-05-2010 09:14 AM
    Warning lights Herniakey1970 V-Class 3 02-24-2008 03:40 AM
    bas esp asc abs lights on (3 lights) ML320 2000 thomasda W163 M-Class 21 02-12-2007 09:51 AM
    no brake lights bas/asr warning lights on cward2105 W123 E,CE,D,CD,TD,TE Class 3 08-12-2006 10:34 PM
    Rant Warning: MY ML320 lost power Steering MBASKIN W163 M-Class 3 04-29-2002 07:45 PM
