ML won't shift out of "Park"... - Mercedes-Benz Forum
post #1 of 13 (permalink) Old 08-26-2008, 04:16 PM Thread Starter
Date registered: Aug 2008
For some reason I can't get my sister's ML to shift out of park. I'm trying to get it out of our garage and the shifter won't move. I daily drive a manual but last I checked in order to put an automatic into gear you press the brake pedal and shift it into the correct drive setting. Any ideas why the car won't shift out of park? Does it have something to do with a bad sensor not recognizing the brake is pressed? Any suggestions or help would be GREATLY appreciated, we can't have this car stuck in our garage...
Cusson is offline
post #2 of 13 (permalink) Old 08-26-2008, 04:35 PM
sstomcat's Avatar
Date registered: Jun 2006
Vehicle: ML-55 - 2000,
Quoted: 20 Post(s)
Brake switch, easy change. Do a search for a diy
AMG 19X9.5 Wheels,
Stock AMG 18X8.5 Wheels
Yokohama Advan S/T 295/45/19 Tires,
Bridgstone Dueller 285/50/18
SCHATZ Chrome Rear hatch handle,
SCHATZ Chrome Headlight Trim
Chrome AMG License Frame,
SCHATZ Chrome Side Light Surrounds,
German Howell Chrome Door Lock Surrounds,
German Howell Chrome Indash Air vent surrounds,
AMG Stem Valve Caps
LED Tail Lights
sstomcat is offline
post #3 of 13 (permalink) Old 08-26-2008, 04:40 PM
Merzatt's Avatar
Date registered: Nov 2007
Vehicle: ML320 2002 Cayman S 2014
Quoted: 76 Post(s)
Problem is most likely failure of brake light switch located juts behind the brake pedal. There are instructions in the user manual how to manually switch gear out of the Park. Drive to MB dealer and buy a brake light switch. Cost is around $20. Search the forum. It is very easy to replace takes about 15 minutes.
Merzatt is offline
post #4 of 13 (permalink) Old 08-26-2008, 04:49 PM
Date registered: Aug 2006
Vehicle: 02 ML320 06 ML500
Quoted: 909 Post(s)
So many people do not have an owner's manual and those who do don't even read it.
43sqd is offline
post #5 of 13 (permalink) Old 08-26-2008, 07:54 PM
Vehicle: 2005 ML350SE
Could be a much bigger problem in the shifter if it got wet.
2005 ML350 SE
20" MB CLS REP WHEELS
8000K XENON
JoeE46M3 is offline
post #6 of 13 (permalink) Old 08-27-2008, 05:04 AM
FAR888's Avatar
Date registered: Mar 2007
Vehicle: 2002 ML55 AMG, 2005 Chrysler Crossfire Coupe Limited, 1999 C280
Smile
Why don't we all at least help him move the truck out of his gararge first as he desires?
Using a ball point pen, insert it into the small hole at the bottom of the gear shift panel and you should be able to move the gear from "Park" to other positions as a temporary measure till you can buy the brake light switch.
Let us know how you get on.
FAR888 is offline
post #7 of 13 (permalink) Old 08-27-2008, 07:08 AM
Quoted: 909 Post(s)
Do not drive the truck as you will have no brake lights.
43sqd is offline
post #8 of 13 (permalink) Old 09-16-2008, 04:47 PM Thread Starter
Thanks for the help guys!
I've actually been out of the country for the last couple weeks and I'm just now getting around to taking care of the Mercedes. So what exactly is a brake switch? Would it be completely unnecessary for me to bring the car to the dealership to have this done. I do lots of work on my own car and I'm thinking it'd be wiser to do it myself.
How hard is the fix? Are there any DIY threads on here?
Cusson is offline
post #9 of 13 (permalink) Old 09-16-2008, 07:02 PM
Quoted: 909 Post(s)
Go to this link and then click on Problems to then left and then click on Brake Pedal Switch goes bad.
The M-Class Outpost - The M-Class Enthusiasts' Site
43sqd is offline
post #10 of 13 (permalink) Old 09-17-2008, 12:17 AM Thread Starter
Originally Posted by 43sqd View Post
Go to this link and the click on Problems to the left and the click on Brake Pedal Switch goes bad.
Thanks a ton for the link! After a quick read through, it's very apparent what a poorly designed setup Mercedes has implemented in the M-Class. Guess I'm heading to the dealership tomorrow to buy the replacement.
Cusson is offline
    Car stuck in park, i-pro scanner reads: "Selector Lever Signal Error" Pro60modman W210 E-Class 2 03-28-2012 05:26 PM
    240 D VS Buick Park Ave. "quality diff." 240D82 W123 E,CE,D,CD,TD,TE Class 16 07-19-2007 07:12 PM
    The "W" and the "S" next to the Gear Shift...(Auto Tranny) MLTHREEFIFTY R170 SLK-Class 10 03-27-2007 07:12 AM
    320 Locked in "Park" 300 miles from a dealership! JKJ W163 M-Class 3 08-22-2002 06:24 AM
