Old 06-27-2008, 03:21 AM   #1 (permalink)
Date registered: Jun 2008
ML500 Power Steering leak
hey all,
Tonight i had the power steering line split or leak, not to sure yet until i take a look, its using a lot of fluid and as soon as you turn the wheel it spues out. It leaks down under the front axle just to the right side ( drivers side) near cv's, has anyone had he same issue or can help???
fastline is offline   Reply With Quote
Old 06-27-2008, 04:29 AM   #2 (permalink)
Date registered: Aug 2006
Vehicle: 02 ML320
Please update your profile in USER CP to include the year and model of your truck.
It could be any number of things..........the pressure line, the return hose, the reservoir, O-rings. You will have to narrow it down a little. But whatever it is, do not continue driving it, you will ruin the pump in no time.
43sqd is offline   Reply With Quote
Old 06-27-2008, 07:32 AM   #3 (permalink)
Date registered: Mar 2008
Vehicle: 2003 ML350
In case it's the reservoir seal, here's a procedure of how to change it posted by a fellow blogger, to save you some time with the search. Good luck.
File Type: pdf power-steering-pump-reservoir-removal[1].pdf (627.8 KB, 18 views)
sergiu is online now   Reply With Quote
Old 06-27-2008, 07:33 AM   #4 (permalink)
Date registered: Nov 2007
Vehicle: ml500 w163 2002
Originally Posted by fastline View Post
hey all,
can't say for certain but it sounds like what you're describing is the power steering hoses torn or lose connection. have a mechanic check asap.
RUEY220 is offline   Reply With Quote
Old 06-27-2008, 09:12 AM   #5 (permalink)
EddieBenz's Avatar
Vehicle: 2001 ML 320
Smile
hey all,
I had that problem too.The dealer at any MB can fix that for free.It was a recall from the Mercedes company,like 2 years ago.Go fix it and do not pay a dimme.
every collision changes the speed and direction of both molecules involved
EddieBenz is offline   Reply With Quote
'99 ML430 Power steering fluid leak from steering rack boot? XxAndrijanXx187 W163 M-Class 10 05-06-2008 12:52 PM
power steering leak pam01ml320 W163 M-Class 16 10-31-2007 02:52 PM
power steering leak help wyman W163 M-Class 6 02-08-2007 01:35 AM
power steering leak colchester450slc R/C107 SL/SLC Class 3 03-03-2004 02:56 AM
Power Steering Leak? Fenix W123 E,CE,D,CD,TD,TE Class 3 01-21-2003 07:47 AM
