» Site Navigation
» Other Sites
Old 06-25-2008, 12:58 PM   #11 (permalink)
Date registered: Oct 2007
Vehicle: 1998 ML320 Silver
The hot-rod community does it all the time. There are wiring looms and electronics available to fool the computer to not throw a check engine light (emissions). Then, you have to tune it.
I suspect that the ML cat problem stems from using the lowest available grade of gasoline. I used to run premium and switched to mid-grade and all seems well. I am scared to try regular 87 octane as we tried in our Toyota with poor results. I have over 187k on my 98. I have seen cats go early on others and have not been covered under warranty.
Pinballer is offline   Reply With Quote
Old 06-27-2008, 02:45 PM   #12 (permalink)
racer c6's Avatar
Date registered: Apr 2008
Vehicle: 1999 ML 430
What we need here is O2 sims like the LS1 and LS6 guys over at Chevy have that do away with the rear O2's all together. I agree that you will need the front O2's for mixture and engine management issues.
I would be a happy man if I could find rear O2 sims to make my damn CEL go off because the heater circuit on a O2 sensor is bad.
racer c6 is offline   Reply With Quote
Old 07-11-2008, 05:50 PM   #13 (permalink)
salex100m's Avatar
Date registered: Jul 2008
Send a message via AIM to salex100m Send a message via MSN to salex100m
Wink yes you can remove your cats
Cats are only used for environmental purposes and can be removed...
BUT... what will happen to YOUR specific car with no CATS?
there are at least two o2 sensors surrounding the cat, at least one in front and one back. The first o2 sensor lives in a pressurized environment (since air is held up a bit by the cats and muffler). The second sensor is under less presure of course.
Any changes in pressue usually lead to o2 sensor failures which cause serious problems with the fuel/air management.
In other words, if you remove your cat from your 320, your o2 senors will fault which will trigger MAF problems undoubtly and probaly kill other systems over time. The best case scenario for you would probably be reduced gas milage due to air/gas mix problems.
Of course not all cars are as sensor dependent as MBs, especially older ones, and removing cats can infact improve gas mileage and performance.
Oh yeah, also removing your cat is illegal in most states if not all.
That being said there is one very good way around having to deal with a cat converter!!!!! Buy a classic car! They are usually not subject to the same exhaust laws as newer cars. BUt then you'll probably get other things rattling....
Just fix the darn thing and make sure your maf and o2 sensors are in working order so that your cat isn't burnt out early after you replace it
1998 SLK 230 150k miles - still running
1972 300 SL 107K miles - still rusting
salex100m is offline   Reply With Quote
Old 07-13-2008, 02:04 PM   #14 (permalink)
Date registered: Jan 2006
high flow cat alternative?
If the cats go bad and replacement is required, is there a high flow cat alternative? As long as you have to replace, you might pick up some performance with less restrictive cats. Anyone know?
Regards,
Jerry
gsfent is offline   Reply With Quote
Old 07-14-2008, 12:59 PM   #15 (permalink)
pointman's Avatar
Date registered: Sep 2003
Originally Posted by tzetter View Post
I'm not going to remove my cats, I didn't say I was, and I am not interested in an environmental demonstration. Cat or no cat driving a heavy, thirsty, SUV is certainly NOT a "green" choice, so kiss your kids while you buckle them into your V-EIGHT.
Now, my technical questions above still stand for anyone willing to offer any input specific to them.
So you're asking cause you thirst for knowledge? Really? Sure?
And search the forum.
No cat = cel
enjoy.
Let us know how fast and furious your 215hp six cylinder is when you are done.
pointman is offline   Reply With Quote
Old 07-14-2008, 01:52 PM   #16 (permalink)
Date registered: Aug 2006
Actually I was, and the driver's side cats have already been replaced with an OEM solution including two new OEM O2 sensors. The attitudes on this site for the most part mirror the MB build quality it would appear.
tzetter is offline   Reply With Quote
Old 07-14-2008, 02:32 PM   #17 (permalink)
FAR888's Avatar
Date registered: Mar 2007
Vehicle: '02 ML55 AMG
Send a message via Yahoo to FAR888
Talking
Ha ha ha - Now you're asking for trouble!
<img src=http://i12.photobucket.com/albums/a208/solidjake/19995.jpg border=0 alt= />
FAR888 is offline   Reply With Quote
Old 07-14-2008, 02:55 PM   #18 (permalink)
bocabenz's Avatar
Date registered: Jul 2006
Vehicle: 2000 ML430
Why thank you... I've only had one small problem with my ML in about 3.5 years.
2000 ML430
Chrome grille, tailgate latch, logo on rims, instrument cluster rings - K&N air filter - Ate brakes - projector style lights w/xenon bulbs - white LED lights on licence plate - handpainted pinstripe - designo Java Shift Surround
NEW! Click to read the New Members Guide
bocabenz is offline   Reply With Quote
Old 07-14-2008, 04:21 PM   #19 (permalink)
MB-SV's Avatar
Date registered: Nov 2007
Wow, that's amazing!
S.
2006 ML350 white/ash
2008 C300 Sport mars red/black
2004 986S seal gray metallic/black/black
MB-SV is offline   Reply With Quote
Old 07-14-2008, 04:47 PM   #20 (permalink)
Vehicle: ml500 w163 2002
someone comes into a bar looking for a fist fight and starts making it personal when the others come back with sticks and knives. I suggest you sell your ML or donate it to a charitable organization if you feel the way you do. We're not here to experiment your troubles and benefit from them. We're here to help and give usefull information but if you can't take good advice go buy a Rolls Royce and be one of the 1 out of 10,000 that drive one.
RUEY220 is offline   Reply With Quote
Catalytic Converters Noodles W163 M-Class 0 06-25-2007 10:24 PM
Catalytic converters.... TheOgre W163 M-Class 11 10-27-2005 09:45 AM
Catalytic Converters Bio W210 E-Class 4 01-14-2005 06:05 PM
catalytic converters Andrew9147 R170 SLK Class 4 09-29-2003 12:40 AM
Catalytic Converters Andrew9147 R170 SLK Class 1 09-05-2003 01:44 PM
