» Site Navigation
» Other Sites
Old 06-22-2008, 05:39 PM   #1 (permalink)
TheGodfather's Avatar
Date registered: Jan 2007
Vehicle: 1998 ML320
Unhappy Worried I found some leaks. Help me identify please
I decided to go under the ML to look for problems like leaks. Well I found two and I have no idea what they are from. I am rather clueless for the most part as to what I am looking at underneath the ML.
Could someone please help me identify where these leaks may be coming from. I am quite worried as I always worry about transmission leaks.
The first, second, and forth pictures were taken at the front of the vehicle. The first picture shows a plug with a red dot, I noticed some rather fluid oil (or like substance) adhering to it.
The third picture is from the rear of the vehicle in the center. The oil is pretty thick and caked.
I have not noticed any grease on the driveway, so these leaks are probably very slow and not so new.
Thank you very much
1998 ML320
TheGodfather is offline   Reply With Quote
Old 06-22-2008, 08:02 PM   #2 (permalink)
Date registered: Nov 2007
Vehicle: ml500 w163 2002
this looks like a leak from the axle seal, or the transfer case.
Thank you very much
RUEY220 is offline   Reply With Quote
Old 06-22-2008, 08:23 PM   #3 (permalink)
Vehicle: 1998 ML320
Thank you very much for the reply,
Which picture shows the location of the transfer case/ axle seal, is this the frontal end leak?
Old 06-23-2008, 12:34 AM   #4 (permalink)
pcy
Date registered: Feb 2005
Vehicle: '98 ML320, '97 328i
The leak shown in the first picture could possibly from one of the following:
- AC line connection to the compressor (the o-ring at the connector may be leaking)
- oil may be leaking from the timing cover plate (replacement of small gasket will solve this)
- Oil may be leaking from the oil filter housing.
- Power steering fluid may be leaking from the reservoir to the pump (gasket may need to be replaced). At worst, the PS fluuid reservoir may need to be replaced.
You will need to closely look at all those above and see which one is leaking.
pcy is offline   Reply With Quote
Old 06-23-2008, 10:48 AM   #5 (permalink)
Vehicle: 1998 ML320
Thank you pcy, I appreciate your response.
Old 06-23-2008, 11:21 AM   #6 (permalink)
ML Mod
ttaleric's Avatar
Vehicle: ML430
Send a message via AIM to ttaleric
Check all the lines coming from the radiator. I had a to replace one recently, had the same results as you do.
System: Alpine CDA-9813, JL w3v2, Phoenix Gold 350.2, Wired all with MosterCable (Power,Ground,Remote,RCA's), Custom Fiberglass box.
Random Mods: AC Chrome Rings, Bosch Platinum 2 spark, K&N Drop-in Filter, OEM Bull Guard, Hella 500 Fog Lights, Updated 02' Headlights, SCHATZ Chrome tip. ML500 Grill. Full spare tire rack! Yakima Roof Rack
ttaleric is offline   Reply With Quote
Old 06-23-2008, 07:09 PM   #7 (permalink)
Vehicle: 2000 ML320, 2005C240 4matic wagon, 1962 220SEb, 1979 300CD
You can tell alot by smell and color. Wipe the suspect area with a paper towel. A pungent odor can be attributed to a leaking axel seal. Power steering will be more of a hydrolic oil smell. Motor oil will have a different smell as well.
yaki b is offline   Reply With Quote
Old 06-23-2008, 07:35 PM   #8 (permalink)
Vehicle: 1998 ML320
The leak from the front where that red dotted plug is, is light in colour where as the leak in the back is thick and coloured black/brown
As far as smell go, I really cant tell, I will try again though.
Thanks,
Old 06-23-2008, 07:48 PM   #9 (permalink)
Vehicle: 1998 ML320
Does any one know of any diagrams of the ML of the underside?
I would easily be able to name the leak if I wasn't so clueless as to what I am looking at.
Old 06-23-2008, 07:51 PM   #10 (permalink)
Vehicle: 1998 ML320
Perhaps I should take it to a regular mechanic to diagnose.
Should I be worried benzmoy W163 M-Class 5 03-18-2008 10:25 AM
I found the solution for the hydraulic struts fluid leaks from the windshield visors interiormagic R129 SL Class 15 11-01-2006 10:40 PM
Can anyone identify this part I found ??? Bazzle ??? MidLife Crisis R170 SLK Class 2 04-13-2006 08:51 PM
Found a loose plug, need help to identify nomada W126 S,SE,SEC,SEL,SD,SDL Class 10 06-27-2005 12:40 PM
Worried... lammett R171 SLK Class 5 12-22-2004 01:05 PM
