» Site Navigation
» Other Sites
Old 06-09-2008, 08:17 PM   #11 (permalink)
AC_ML's Avatar
Vehicle: Black 2005 ML 500
Air conditioning not working - mechanic says need new AAM?!
Hopefully some helpful info below..
http://www.benzworld.org/forums/w163...oling-tsb.html
AC
2005 ML 500
Black, 18" AMG Wheels, 285/60R18 Falken Ziex ST/Z + Bi-Xenons(+ Drew's e-code mod), Yakima roof bars. Former vehicle 2001 ML 320 with 108K miles, when traded, and a large repair/defect history.
AC_ML is offline   Reply With Quote
Old 06-09-2008, 08:36 PM   #12 (permalink)
Date registered: Aug 2006
Vehicle: 02 ML320
When the truck starts blowing ambient air you must leave the truck running, open the hood and check to see that the clutch on the front of the compressor pulley is turning. If it is turning, then you have an Air Mixture Door motor problem. If it isn't turning then you have an elec. problem or a low charge problem.
43sqd is offline   Reply With Quote
Old 06-09-2008, 09:11 PM   #13 (permalink)
Date registered: Dec 2006
Vehicle: 1998 ML320, 220K miles
Interesting. I thought I did feel the A/C compressor cycle on and off during the time when it was blowing ambient air. Not 100% sure though, I will check the compressor pulley tomorrow...if the problem happens again tomorrow.
acorad is offline   Reply With Quote
Old 06-10-2008, 03:11 PM   #14 (permalink)
Well, the [edit: clutch] is definitely NOT turning when the A/C doesn't work.
Would an AAM problem be intermittent like this?
Sure hope it's a low pressure/leak problem...
Old 06-10-2008, 03:21 PM   #15 (permalink)
Bogie's Avatar
Vehicle: 2002 ML 500, 1994 Ford Explorer donated to Doctors without Borders
Did you check to see if your system is charged? I'm going through the same thing now. It took me 15 minutes to charge it yesterday and I have cold air. I'm watching to see if it will remain charged. If you have no refrigerant, nothing is going to work.
Bogie is offline   Reply With Quote
Old 06-10-2008, 03:53 PM   #16 (permalink)
Thanks Bogie, I'm at work today so I haven't been able to check to see if it is charged. I will, hopefully this afternoon.
Old 06-10-2008, 04:28 PM   #17 (permalink)
Vehicle: 02 ML320
Originally Posted by acorad View Post
Well, the pulley is definitely NOT turning when the A/C doesn't work.
Maybe we are not on the same page. The pulley is the part where the belt revolves around, the CLUTCH is the round object in front of the pulley.
When the engine is running is the clutch also turning?
Old 06-10-2008, 05:45 PM   #18 (permalink)
Sorry, yes, the CLUTCH on the front of the pulley is not turning during those times when the A/C blows hot air. It is turning when the A/C's blowing cold air.
PS: Thank you for the effort of scanning and uploading a pdf, that's above and beyond the call of duty!
Old 06-11-2008, 03:29 AM   #19 (permalink)
Vehicle: 02 ML320
Being that your A/C worked for one month, it is safe to assume that a non signal from the AAM would have surfaced during that time. So the only logical conclusion is that during the month after the mech. charged your system, the truck has lost enough refrigerant, causing the system to operate on a "sometimes" basis.
Yes it is true that the AAM (in this model year) turns the compressor on, but I still believe that something is telling the AAM not to turn on the compressor and that the AAM is not the problem. Remember that replacing the AAM is more involved than what your mech. believes. It will have to be programmed by the dealer only, since among other things, it includes your key recognition system.
Look at the pdf below and inspect all the A/C lines, and see if there are traces of refrig. oil anywhere; that would indicate a leak. Also remove the elec. 3 wire connector to B12(Pressure Switch) and see if there is any trace of corrosion, (usually green).
My suggestion would be that you go to another mech. who has an evacuation/recharging machine, and simply ask him to recharge your system and attempt to find the source of the leak and see what his opinion is. Absent any under-hood leak, and based on the age of your truck, I'm afraid that you have a leak in the evaporator which is behind the instrument panel, which is super expensive to replace.
Do not tell the mech. that you were elsewhere or that this forum suggested anything, simply ask for a recharge and check for leaks. If he can't find any leaks and it is properly charged, I can almost guarantee you that the system will work trouble free for another month or so, until the refrig. has leaked out again.
Old 06-11-2008, 07:46 AM   #20 (permalink)
Date registered: Mar 2008
Vehicle: 2003 ML350
43sqd,
On the PDF file you posted, which one is the evaporator, part #2 (maybe?). I believe the expansion valve should be there also but I don't think is marked. I know this has been an issue in a recent thread in which some of you most knowledgable ones were contemplating a clogged expansion valve. Acorad said at one point that his mechanic purged some of the cooling agent the due to overcharging. Could that high pressure detected be because of a clogged expansion valve? in which case purging some of the pressure in the system would make the problem worse.
sergiu is offline   Reply With Quote
98 slk 230 air conditioning stopped working calshawn R170 SLK Class 5 05-27-2008 03:45 PM
Air conditioning not working cmitch W163 M-Class 22 04-25-2008 03:26 AM
Does the outside air temperature effect air conditioning? e320 cabrio swanny2070 W124 E,CE,D,TD Class 5 07-11-2007 11:14 AM
air conditioning fan not working! Selma W201 190E, D-Class 3 04-23-2005 04:48 PM
Air conditioning not working..... supersport6 W126 S,SE,SEC,SEL,SD,SDL Class 1 05-12-2004 03:15 PM
