» Site Navigation
» Other Sites
Old 05-14-2008, 09:34 AM   #1 (permalink)
Date registered: Dec 2006
Vehicle: 1994 Mazda Miata, 1987 Ford F150, 1986 Honda Civic
98 320 no start! help
ok, the central locking system is on the fritz again on my boss' 98 ML320. so he decides to pull all fuses one by one and check and replace. that didn't fix it, so he then tries to start it and it won't start. all fuses are correct. the tach moves so it's not the CPS, i can hear the fuel pump prime. it cranks, but doesn't turn over. i'm thinking he tripped the a theft device, but i don't know. any help is much appreciated!
Earthwalk is offline   Reply With Quote
Old 05-14-2008, 11:29 AM   #2 (permalink)
Premium Member
cmitch's Avatar
Date registered: Apr 2005
Vehicle: '99 ML 430, 2002 ML320
Premium Member
It could be a myriad of things. It still could be the Crank Position Sensor. It could also be the AAM (Drive Authorization system is integrated in the All Activity Module) or a couple of other things. I'd try a battery disconnect for 15 minutes, then try again. FYI, the tachometer does not move on either of my ML's until they crank up. Go figure.
Be careful about reading health books. You may die of a misprint.- Mark Twain
cmitch is offline   Reply With Quote
Old 05-14-2008, 12:47 PM   #3 (permalink)
azinn's Avatar
Date registered: Apr 2003
Vehicle: 2000 ML 430, 2007 Scion tC
My money is on a bad CPS. If the CPS has never been replaced in your truck I would replace it. My 2 cents.
azinn is offline   Reply With Quote
HELP! S-320 will not start! but finally got to start with direct power to starter Newinport W140 S-Class 8 03-21-2008 09:58 PM
ML 320 (2000) does not start usmanfar82 W163 M-Class 6 01-11-2007 11:53 AM
sporadic no start 1994 E-320 adams587 W124 E,CE,D,TD Class 0 10-22-2005 07:10 PM
ML 320 will not start in HOT weather KnicK General Mercedes-Benz 7 09-01-2005 09:56 AM
1998 ML 320 won't start TWhyte W163 M-Class 12 06-12-2004 05:01 AM
