» Site Navigation
» Other Sites
Links
» Tire Upgrade Garage
Old 05-06-2008, 01:02 PM   #1 (permalink)
wacsr7431
wacsr7431's Avatar
Date registered: May 2008
Vehicle: 2002 ML320
Send a message via Skype™ to wacsr7431
Start Error / Key Problem
Hey folks, Let me start by saying "Another one bites the dusk". My 02 ml320 fail to start yesterday. I've Never heard of, or have experience this problem before. After joining this site I read just about everything i could find on this start error/key Problem. I Went back up to the car where it failed (I was hopeing to get it started so I could get it home) removed the battery and tried to start it again. Just like the forum said, 3 tries and it was over. I tried both keys to no avail.Only other option was to call the tow truck. They picked it up today headed to the shop. Called the Benz dealer, they said very proudly.."Sure, bring it in, we can surley fix it!"(I could hear the cash register in the back ground, chig,chig) I called my Certified Benz import shop that has been doing all the work for the last 3 years. He said" Naw, never have heard of that before, but you know we will take care of you, bring it in" Man, I tell you.. It's not looking good either way. let me say, I've only had one problem with the small SUV since I've had it(back seat got suck in the down position) Cost me about $300 to get it up and new cable. So I guess I am due. I will let you folks know my out come.....Oh, I took it to my Import guys.
wacsr7431 is offline   Reply With Quote
Old 05-06-2008, 01:13 PM   #2 (permalink)
43sqd
Date registered: Aug 2006
Vehicle: 02 ML320
There are a number of things that could cause a no start, but one suggestion is that you check the odometer window on the instrument cluster and if it says START ERROR in place of the mileage, then no repair shop can fix the problem. It is the DAS (Drive Authorization System) which can only be purchased and coded by a M/B dealer. Before your mechanic starts replacing parts to try and get the truck running, it would be financially beneficial to you both, if you find this out as soon as possible.
43sqd is online now   Reply With Quote
Old 05-06-2008, 01:18 PM   #3 (permalink)
wacsr7431
wacsr7431's Avatar
Vehicle: 2002 ML320
It does say start error in the mileage spot. I printed off the pdf you have attached and sent it to them with the car....thanks..
Old 05-06-2008, 01:18 PM   #4 (permalink)
cmitch
Premium Member
cmitch's Avatar
Date registered: Apr 2005
Vehicle: '99 ML 430, 2002 ML320
Premium Member
Drive Authorization System (DAS). It's not cheap. Luckily, the DAS is separated from the AAM in 2001. If it were a pre 2001 model, you'd been out some much bigger bucks. I think this repair is between $700 to $900.
Sorry, 43sqd. I was doing a DAS search while you posted your response.
Be careful about reading health books. You may die of a misprint.- Mark Twain
cmitch is offline   Reply With Quote
Old 05-06-2008, 01:20 PM   #5 (permalink)
AC_ML
AC_ML's Avatar
Vehicle: Black 2005 ML 500
Last year I had the problem 43sqd is talking about.. Make sure you take all your keys because they will need to be re-programmed..
"Start Error" on Instrument Cluster Mileage Display when Cranking
AC
2005 ML 500
Black, 18" AMG Wheels, 285/60R18 Falken Ziex ST/Z + Bi-Xenons(+ Drew's e-code mod), Yakima roof bars. Former vehicle 2001 ML 320 with 108K miles, when traded, and a large repair/defect history.
AC_ML is offline   Reply With Quote
Old 05-06-2008, 01:23 PM   #6 (permalink)
cmitch
Premium Member
cmitch's Avatar
Premium Member
AC
I have not had my error since last October. My fingers are still crossed.
Old 05-06-2008, 01:34 PM   #7 (permalink)
43sqd
Vehicle: 02 ML320
Who did you send the truck to?
Old 05-06-2008, 01:42 PM   #8 (permalink)
43sqd
Vehicle: 02 ML320
You know Mitch, these problems are popping up quite often, and I really feel for these guys who have the first version, which only seems to be a money maker for Mercedes. I still can't understand why they couldn't just issue a recall and end this nightmare. I guess they have very large checkbooks and can out wait anyone in court. That's why it is very hard fighting them.
Old 05-06-2008, 02:56 PM   #9 (permalink)
cmitch
Premium Member
cmitch's Avatar
Premium Member
I expect to hear even more as these trucks get older. I wonder if reporting this start fault to the NHTSA as a safety issue would do any good? A non-starting vehicle is potentially life threatening, especially if it happens after hours in a less than nice neighborhood.
Old 05-08-2008, 11:49 AM   #10 (permalink)
mlfun
Date registered: Feb 2006
The bulletin you posted covered all ML's 2000 - 2005.
What is circuit 15 ?
mlfun is online now   Reply With Quote
Start error Mk85 General Mercedes-Benz 2 11-16-2007 05:25 AM
start error bonta V-Class 22 10-16-2007 03:35 PM
Start Error !!!! timer W168 A-Class 2 12-28-2006 01:53 PM
key fob error help! berk R170 SLK Class 4 12-12-2006 05:31 PM
Key Problem will not start C230k melttemp W203 C-Class 4 12-01-2006 02:29 PM
