Old 04-25-2008, 04:53 PM   #1 (permalink)
Date registered: Feb 2008
Vehicle: 2003 Mercedes ML 320
Aftermarket stereo install
I am going to sound rude here but let me ask again if anyone has done this. I appreciate everyones opinions but I need expertise here. I have the head unit out of the vehicle and the wiring diagram for the unit. I have also removed the amp. There are speaker wires, power, ground and fiber optic to the amp. Does anyone have the wiring diagram from the amp to the speakers. I have to bypass the amp or install an aftermarket 4 channel that will handle a 2 ohm load. Noone on this forum in the last week has been able to provide the wiring "pins" for the amp. I have been sent pictures of what the amp looks like duh, The wiring diagram from Wolfgangs site for the head unit "awesome" but I still can't finish this job without that diagram. Can someone please step up and provide me with some info here I am begging. If you have done the job, share your expertise, if you just want to bs or show pictures of your car, some other time. I know I sound nasty here but I am desperate for help please!!!!!!!
61loub is offline   Reply With Quote
Old 04-26-2008, 10:26 AM   #2 (permalink)
MJ50's Avatar
Date registered: Nov 2003
Vehicle: C240 & ML350
Send a message via ICQ to MJ50 Send a message via AIM to MJ50 Send a message via MSN to MJ50 Send a message via Yahoo to MJ50
sorry, no clue on wiring diagram...
i just let the pros do the work...
2003 C240 done modding
2004 E55 MBenzNL, RENNtech pulley, ECU, VRP split cooling
2004 ML350 modded & sold
MJ50 is offline   Reply With Quote
Old 04-26-2008, 05:25 PM   #3 (permalink)
Date registered: Nov 2007
Vehicle: 2005 ML350SE
Ok, you can wire the headunit directly to the speakers (at the amp). The headunit wants 4 ohm speakers...the bose are 2 ohm. It will work, but IMO It doesnt sound that good and you can barely use any bass (you are going to lose your underseat sub).
For the time being, get the headunit installed and find the speaker wires at the amp (left front, right front, left rear, back rear) and get speaker wire to splice them into the head unit (4channel). The factory amp is worthless now.
You dont need any diagram at this point. Just find the wires coming out of the amp and splice into them. Have the head unit hooked up with the wire leads extended...get under the dash and start connecting them. You will hear what door speaker goes with each wire.
2005 ML350 SE
20" MB CLS REP WHEELS
8000K XENON
JoeE46M3 is offline   Reply With Quote
Help with aftermarket stereo install 61loub W163 M-Class 11 04-21-2008 09:54 PM
Aftermarket Stereo Install?? REDBULL27 Audio & Telematics Forum 0 12-14-2007 10:07 AM
Aftermarket stereo install help Hapa88 R170 SLK Class 13 09-09-2005 10:01 AM
Aftermarket stereo install help on '01 SLK Hapa88 Audio & Telematics Forum 1 09-07-2005 02:22 PM
NO ONE WANTS TO INSTALL AFTERMARKET STEREO!! Carcus 98 ML W163 M-Class 5 02-28-2003 07:38 AM
