» Site Navigation
» Other Sites
Old 04-25-2008, 05:01 AM   #1 (permalink)
prostoilyich
Date registered: Apr 2008
Problem: rapid up-down rpm at idle
Hi, guys!
My 1999 ML430 developed a problem after I accidentally left the lights on and had to jump-start the car. Engine RPMs rapidly going up-and-down every 1-1.5 seconds. Engine sort-of making VROOM-VROOM sound. Pressing on accelerator pedal has no effect whatsoever. I've tried to disconnect the battery hoping to reset the computer, no luck. BAS/ESP light is on. and trying to clear it turning the steering wheel left-right-left did not work. CHECK ENGINE light is OFF.
What could be the culprit and what can I do, other then have it towed to dealer for diagnostics?
I'll really appreciate your advice.
Thank You!
Vladimir
'99 ML430
198,000 miles
prostoilyich is offline   Reply With Quote
Old 04-25-2008, 02:17 PM   #2 (permalink)
43sqd
Date registered: Aug 2006
Vehicle: 02 ML320
Remove the neg. battery cable again for 2-3 mins. then reattach. Turn the key to the run position, but do not start the truck, after two mins. slowly depress the gas pedal and slowly let it up. Turn the key off and then start the truck, but do not rev the engine, let it idle on its' own for a while so it can go through the relearn process.
43sqd is offline   Reply With Quote
Old 04-25-2008, 03:27 PM   #3 (permalink)
prostoilyich
Fantastic!
That solution worked!
Thank you very much, 43sqd!
Vladimir
Old 04-25-2008, 10:36 PM   #4 (permalink)
designo?
Vehicle: ML 500 '02 & 300 SE '89
What adaptation is this procedure?
ML 500 '02
300SE '89
525iA '89
944 NA '85.5
928 '80
928 '80
4Runner '95
designo? is offline   Reply With Quote
Old 04-26-2008, 03:30 AM   #5 (permalink)
43sqd
Vehicle: 02 ML320
For the Pedal Value Sensor and the Elec. Throttle Actuator.
Rough idle at stop light / What is normal idle rpm? projectpete19 W208 CLK Class 3 03-11-2008 12:56 PM
Rough idle at stop light / what is normal idle rpm? projectpete19 W209 New CLK Class 0 03-06-2008 10:59 AM
ROUGH IDLE, IDLE CONTROL UNIT LOCATION, TIMING & RPM verdejor W126 S,SE,SEC,SEL,SD,SDL Class 16 02-15-2006 10:52 AM
ROUGH IDLE, IDLE CONTROL UNIT LOCATION, TIMING & RPM verdejor General Mercedes-Benz 5 01-22-2006 08:41 PM
RPM unstable at idle, anyone has this problem? noelb W163 M-Class 4 12-17-2001 03:05 PM
