» Site Navigation
» Other Sites
Old 04-23-2008, 01:23 AM   #1 (permalink)
Date registered: Sep 2007
02 ML320 fuel pump problem?
After doing oil change myself, I found that the engine is very hard to exceed 5K rpm even I fully pressed the accelerator (at P, not N).
On road, I start from 0 mph then fully pressing the accelerator, it reaches 40mph after 6 second. However, the acceleration is much lower than before.
I guess the fuel pump needs change, also the fuel filter. I did not see any check engine light and other problem.
Is my feeling reasonable?
Another idea is that, if I just keep the current situation, I feel I can improve the fuel economy as it hardy let me over accelerate. Right?
stojakovic is offline   Reply With Quote
Old 04-23-2008, 02:19 AM   #2 (permalink)
Date registered: Aug 2006
Vehicle: 02 ML320
I wouldn't be so quick to condemn the pump and filter. The problem you describe points to having one or both of your catalytic converters being clogged. Have the problem diagnosed before replacing parts.
43sqd is offline   Reply With Quote
Old 04-26-2008, 05:44 PM   #3 (permalink)
It runs OK, I mean, it runs at 60mph smoothly. The problem is the acceleration speed.
Anyway I can check if it is catalytic converters being clogged myself?
Installation instructions for ML320 Fuel Pump sesproul W163 M-Class 36 05-27-2008 09:45 PM
Fuel Pump for MY2001 ML320. benjaminl W163 M-Class 0 03-21-2007 08:34 PM
'98 ML320 Fuel Pump Replacement Cost elk127 W163 M-Class 7 02-12-2007 05:33 PM
How to replace the Fuel Pump in a ML320 sesproul General Mercedes-Benz 4 10-31-2005 11:22 AM
Update on Fuel Gauge Problem: Got Fuel Pump Replaced Today tjhsiao W163 M-Class 4 10-25-2002 04:47 PM
