Old 04-17-2008, 12:57 PM   #1 (permalink)
Vehicle: 2000 Clk430
ML55 brakes/rotors onto a CLK430?
would this work
thanks
humplok is offline   Reply With Quote
Old 04-17-2008, 01:10 PM   #2 (permalink)
Date registered: Nov 2007
Vehicle: ml500 w163 2002
Originally Posted by humplok View Post
would this work
thanks
You mean work without any modifications and as straight bolt on?
if it works then most likely it would mean that you can put CLK430 brake kits onto an ML55 if they were interexchangeable. I know the rears might not work because the ML rear disc has the parking brake shoes inside.
Also, why would you like to do this since it's not even a good brake kit. I'm trying to get rid of mines.
RUEY220 is offline   Reply With Quote
Old 04-17-2008, 06:51 PM   #3 (permalink)
Date registered: Aug 2005
Vehicle: 02 C32, 08 C350, 00 CLK320 (sis'), 01 ML430 (gone)
Send a message via AIM to FrankW Send a message via MSN to FrankW
don't have the ML anymore, but just sharing what i know.
the ML has completely different hat/rotor than the CLK. The caliper would most likely need to be machined at the mounting bracket or extra mounting braket has to be machined. the rotors will not work at all.
W208 can use the front brakes from W202 and W210 as far as i know. It'll be easier for you to get the W203 bbk i.e. the C32/55 or the 05+ sport brakes from the C230/350 sports. you'll still need to modify the bracket tho.
2002 M112K with lots of mods
2008 M272 with some mods
to do list: install heat exchanger for m112k.
FrankW is offline   Reply With Quote
Old 04-17-2008, 08:56 PM   #4 (permalink)
Vehicle: 2000 ML55
What you want is C32 fronts
toclk43 is offline   Reply With Quote
brakes/rotors done 430convertible W208 CLK Class 4 04-29-2007 12:11 PM
Brakes and Rotors endodoc W211 E-Class 10 03-28-2007 01:19 AM
Changing my rotors and Brake pads on CLK430 myself walterf W208 CLK Class 4 07-13-2006 10:07 PM
CLK430 brakes smoothb001 W208 CLK Class 15 11-03-2004 12:45 PM
Brakes and Rotors Guest (MBNZ) W124 E,CE,D,TD Class 5 03-22-2002 05:24 PM
