i changed my suspension back to stock few days back so here you go. let me know what dimension apart from pictured you need and i'll provide that. three corner bolts are M8.
from hole cntr to left edge 59-60
from hole cntr to low edge 49-50
measured with digital caliper. last two measurements were hard to take due to plate being mounted with the shock. i guess you can do math to figure out their precise values based on other values.
seeing your drawing skills i guess it would be better to name dimensions not by question marks, but something like a,b, c etc. anyway 106 and 96 are top two marks on your drawing. 104 and 101.6 - far left ones. 79.25 - far right, 79 - lowest. then hole diameter which is 52, and two last ones measured from the centre of large hole: from centre to left edge 59..60 and from centre to lower edge 49..50. is it better now?
