ML 500 Oil Change Help Needed - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W163 M-Class
Old 03-30-2008, 07:13 PM   #1 (permalink)
Wizz190E's Avatar
Date registered: Nov 2006
Vehicle: 92 190E 2.6, 06 C280 , 87 Porsche 944
I am changing the oil in my mom's 04 ML 500 this week. What weight Mobil 1 should I use and is there any pic by pic instructions anywhere here ? I searched and didnt come up with any.
Wizz190E is online now   Reply With Quote
Old 03-30-2008, 07:34 PM   #2 (permalink)
Date registered: Mar 2008
Vehicle: Mercedes Benz ML BRABUS
i use mobile 1 fully synthetic 10w 30 in mine but thats just me.
Brabus77 is offline   Reply With Quote
Old 03-30-2008, 08:13 PM   #3 (permalink)
got8's Avatar
Date registered: Dec 2007
Vehicle: 2007 GL450
mobile1 0-40, it say "For European Cars" on it.
got8 is offline   Reply With Quote
Old 03-30-2008, 08:16 PM   #4 (permalink)
Mac
That would be: sucking up ~ 8 quarts using the dipstick tube and a oil-change suction pump . . .
Link: http://www.benzworld.org/forums/w163...-bad-idea.html
Nope, not a bad idea: apparently, that is how MB designed the e_ngine to be drained, e.g., "Since the early '70s all Mercedes engines have been designed for vacuum oil extraction . . . the factory recommended method of oil removal. . ."
Mac is offline   Reply With Quote
Old 03-30-2008, 08:17 PM   #5 (permalink)
Date registered: Feb 2007
Costco Mobil 1 10w30. Oil Change Link
ML-O-PHILE is offline   Reply With Quote
Old 03-30-2008, 08:55 PM   #6 (permalink)
Vehicle: '05 ML350SE
The truck requires 0W-40 Euro Mobil 1 as stated above. Other approved oils are listed at Wolfgang's ML Page under SHOP TALK.
Here is a link to a DIY article which appeared in the STAR some years ago:
http://www.whnet.com/4x4/pix/lamb_01.jpg
It is part of a series on DIY topics for the M.
Tom DeTemple
Denver
'99 ML320 traded @139k miles for---
'02 ML320 traded @45k miles for---
'05 ML350SE now at 104k miles
mickey.1430 is offline   Reply With Quote
Old 03-31-2008, 09:08 AM   #7 (permalink)
Michael Pillay's Avatar
Date registered: Oct 2003
Check your owners manual to see how much oil you need. I would only use Mobil 1 0W40. You can buy the mityvac 7201. I have had one of those. I got a pneumatic pump for Griot's Garage as a birthday present last summer. That is really nice. You will need a compressor though. If not, the mityvac works just fine.
You can get a filter from the dealer or locally. Just pump the oil out of the fill tube, remove the filter. Replace oil and filter and dipstick. Torque the filter cover to 25Nm. You should check and see to confirm this number. It is right on the plastic cover. A "B" cup oil filter wrench is useful. Harbor Freight has them cheap but you can get them just about at any parts store.
Good luck. This is a pretty straightforward job. I am sure you will do just fine.
I would really use Mobil 1 0W40.
Mike
Michael Pillay is offline   Reply With Quote
Bookmarks
SL 500 M119 oil change. RedLiner R129 SL Class 60 05-03-2011 10:54 AM
Tranny Oil change needed? e-raymond R170 SLK Class 19 03-17-2008 08:14 PM
05' CLK 500 Oil Change Help alans1 W209 CLK Class 0 11-26-2006 05:35 PM
Low mileage oil change ? (Is it needed.) bikerider58 General Mercedes-Benz 14 01-13-2006 01:56 PM
Oil Change - stuff needed tuRRtleSpeed W163 M-Class 2 11-29-2005 03:35 PM
