» Site Navigation
» Other Sites
Old 03-20-2008, 09:23 PM   #1 (permalink)
Date registered: Jun 2004
Vehicle: '01 ML320, '03 C240
Electrical Gremlins
Hi
Tonight, I was driving along about 40km/hr when suddenly I realised my left signal light on my dashboard was ON, (not flashing) without me touching the signal stalk at all... i try to signal RIGHT then LEFT, but that doesnt solve the problem.... I turn on my hazard lights and that cancels the left signal light...
Later on (no engine restart), my headlights turn off for no reason, toggling the headlight stalk does nothing to solve the problem either... I turn off the truck, restart it, and the problem went away...
Has anybody encountered a similar incident as described? I should say that I have a 2001 ML320 since new, original battery and have aftermarket HID headlights.
Any input will be greatly appreciated!
patrickc is offline   Reply With Quote
Old 03-21-2008, 06:34 AM   #2 (permalink)
pcy
Date registered: Feb 2005
Vehicle: '98 ML320, '97 328i
Your 'combination switch' is on it's way out and very likely the symptoms will get worse and eventually you 'll need to replace that combination switch.
pcy is offline   Reply With Quote
Old 03-21-2008, 03:10 PM   #3 (permalink)
Date registered: Aug 2006
Vehicle: 02 ML320
I concur with pcy. Had a similar issue with another ML. When both headlights worked the radio would go out. When one headlight went out the radio would play. This must occur because the lighting system runs through the AAM and EAM along with a host of other features.
43sqd is online now   Reply With Quote
Old 03-22-2008, 07:34 AM   #4 (permalink)
Hi pcy,
thanks for your response!
does anybody have a DIY or instructions on the replacement of the combination switch? After doing a search on this topic, it seems that an old batttery may also be the culprit...
any other ideas?
thanks!
Electrical Gremlins! Nimrodthewombat W140 S-Class 2 11-27-2007 03:43 PM
electrical gremlins??? NüR-SPEC W126 S,SE,SEC,SEL,SD,SDL Class 12 04-25-2007 03:52 PM
Electrical Gremlins are here... Horus R129 SL Class 1 03-01-2007 05:13 AM
Electrical Gremlins thamberg W140 S-Class 8 02-22-2006 05:53 PM
Electrical Gremlins - Please Help dickmac1522 W124 E,CE,D,TD Class 1 03-30-2004 01:45 PM
