Old 02-01-2002, 11:29 PM   #1 (permalink)
mdraney
Posts: n/a
2002/refit express window switches etc
how much work involved and is it possible to put the new 2002 express switches in, do you have to also install different parts into the doors?
Old 02-02-2002, 08:58 AM   #2 (permalink)
sosh
Posts: n/a
Re: 2002/refit express window switches etc
Should involve differnt parts in the doors, different switches, different consol and more. Not really worth it.
Old 02-02-2002, 11:11 AM   #3 (permalink)
Drew
Posts: n/a
Can't do it...
The new switches are completely different than the older ones since they're not around the gearshift console rather than behind it. The system also has pinch protection now (because of the one-touch up feature), something that the pre-'02 MLs do not have.
Old 02-02-2002, 03:36 PM   #4 (permalink)
sosh
Posts: n/a
Re: Can't do it...
That pinch protection can be a problem. Mine when using the one touch up still intermittently go all the way up then down an inch or so. Happens less frequently that before the factory tech had a go about fixing but still occurrs. He looked at it in Nov and was supposed to get back to me about possibly changing all the window track insulation but have not heard from him. They did change everything in the system before
Old 02-02-2002, 04:14 PM   #5 (permalink)
Drew
Posts: n/a
Re: Can't do it...
Sosh, I know that for the E and S-class, you can reset the pinch protection by raising the window all of the way up by pressing and holding the switch (the procedure is in the manual). I haven't checked the '02 ML's manual, but I wonder if there is a similar way to do this?
