» Site Navigation
» Other Sites
Old 03-13-2008, 02:44 PM   #11 (permalink)
Date registered: Aug 2006
Vehicle: 02 ML320
Originally Posted by laxman0324 View Post
Do you have that saved somewhere and always copy and paste it? I must have seen it 20 times already
Yes I do. I feel it's important before suggestions are given; point of fact, this thread............no year, no model.
43sqd is offline   Reply With Quote
Old 03-13-2008, 03:21 PM   #12 (permalink)
Vehicle: 99 ML 430
Originally Posted by MADSLEG View Post
AGAIN
there is TWO motors- TWO
one behing your radio and another one kinda behind passenger airbag
I had to replce one behind p. airbag !!!
search for pics if you want
Thanks MADSLEG, I get that there are two motors, which is what my confusion, which one do I replace? Are your instructions for the Air-blend motor, if so, can this this accessed by removing the center console? And I did find your pics, I believe I linked to them in my first post
Originally Posted by Merzatt View Post
Air blend door is the one responsible for mixing hot and cold air. It is visible through the radio hole, for you to check it. But there is not enough space to do the repair. Therefore you will also remove the center console. 43sqd posted the PDF instructions for that. Madsleg did the same repair after removing the airbag and glovebox compartment.
So the same fix that MADSLEG has can be done by removing the center console? And it's the same motor that can be viewed by taking the radio out? How is this possible, since the one MADSLEG talks about is clearly behind the airbag and ergo would not be visible with the radio out. Clearly the motor MADSLEG has in his fix is too deeply buried behind the airbag, no?
Originally Posted by 43sqd View Post
Rainman, I wish you would all let us know what year and model ML you have. If you own a 1998-2001 then your motor looks like #53. If you own a 2002 and above then it looks like #54 , but both motors are in the same exact position; they only look different.
Ok, so this motor can be accessed one of two ways:
1: Remove the center console
2: Remove the glove box and airbag
Sorry, it's the same questions I've asked several times now, but I'm still un-clear on what the answer is.
I could've sworn I had this in there, but it's updated now for your perusal
rain///man is offline   Reply With Quote
Old 03-13-2008, 08:09 PM   #13 (permalink)
Merzatt's Avatar
Date registered: Nov 2007
Vehicle: '02 ML320
Rainman, instructions (upto VIN A289564) from MB to replace blend air flap actuator says the first step is to remove the Instrument panel. If MB says so, I assume a mechanic's arm should be able to reach there. From that picture taken from an angle, it looks like the actuator might be located closer to the airbag. I cannot tell you why they advised to remove the instrument panel. My guess is that MB did not want their mechanics to mess with the airbag units every day.
When I fixed the actuator for center air duct flap, I had to remove the instrument cluster (not the panel) and worked through a very small hole. Removing the instrument panel should give you a lot more access space. It will not be an very easy job for someone doing it first time but, one can figure it out one step at a time.
Merzatt is online now   Reply With Quote
Old 03-14-2008, 02:24 PM   #14 (permalink)
Vehicle: 99 ML 430
Thanks Meraztt.
Do you know where I can find instructions on how to remove the center console?
Old 03-14-2008, 03:54 PM   #15 (permalink)
Vehicle: 02 ML320
Below you will find the procedure to remove the center section. First disconnect the negative battery cable, then the radio and then the center section.
After that remove the glove box and the passenger's side air bag. Working with your right arm in the gove box opening and your left arm inside the center section you should be able to remove the two screws that hold down the air blend motor. It is tricky but it can be done.
Old 03-14-2008, 04:01 PM   #16 (permalink)
Vehicle: 99 ML 430
Thanks!!!
Darn! seems like I'll have to take the air bag out after all.
Air/Fuel mixture: Strange reading on Oscilloscope BenzFlieger W124 E,CE,D,TD Class 6 07-29-2007 06:02 AM
Air-fuel Mixture Screw Is Screwed Up! Stickman W124 E,CE,D,TD Class 2 07-04-2006 10:29 AM
Air to fuel mixture F'd up MPG bigbillybob991 W126 S,SE,SEC,SEL,SD,SDL Class 1 11-19-2005 08:17 AM
adjusting fuel air mixture ratio william.wood W126 S,SE,SEC,SEL,SD,SDL Class 5 11-11-2005 12:25 PM
Adjusting the air/fuel mixture ! hyprr1 W124 E,CE,D,TD Class 0 05-18-2005 08:03 AM
