Old 02-20-2008, 04:28 PM   #1 (permalink)
J-bird's Avatar
Date registered: Oct 2003
Vehicle: 2000 ML320 & 1997 Boxster
12V aux outlet under glovebox stopped working.
Hi All,
Back with another question. I had my satelite radio plugged into the 12V aux outlet under the glovebox and one day it just up and quit working. I am using the lighter in the ashtray for now, but it looks a mess.
I searched everywhere in the fuse box index to see what fuse controls that outlet, and it completely eluded me. The rear aux was identified but not the front! Who here knows which fuse controls the front aux outlet.....or any other ideas for a fix.
Thanks again for all the help! When it warms up a bit I will get to cleaning under the front wiper cowl to try to eliminate my leak!
OH my, I did a bit of searching in the archives and didn't realize there is a fuse box on the passenger side footwell area....I guess I will check that in the morning! It does pay to search!
MY00 ML320
65K miles / Black Opal / M1 Package
Sunroof / Heated Seats / CD Changer
Mods: Front Plate delete / Badge delete /35% tint front windows / OEM Trailer Hitch / OEM Step Bars
MY97 Porsche Boxster
53K miles / Ocean Blue / Sport Package / Hard Top
Mods: B & M Short Shifter / MY00 Shift knob & boot / SS intake grills / Badge delete / front plate delete
Track/AutoX Shoes: Kumho Victoracers
Street Shoes: Kumho Ecsta 712's
J-bird is offline   Reply With Quote
Old 03-19-2008, 02:29 PM   #2 (permalink)
Benzona's Avatar
Date registered: Jan 2008
Vehicle: 2000 ML320
Same issue I am having. I thought it was F1 but when I opened up the fuse box there was no fuse in it.
I have no special talents. I am only passionately curious.
Benzona is offline   Reply With Quote
Old 03-19-2008, 02:41 PM   #3 (permalink)
porschenut's Avatar
Date registered: Aug 2007
Vehicle: 2000 ML55 AMG
I have the same problem. It stopped working while I was using one of those mini tire inflators.
I've checked all the fuses in both fuse boxes and they're all still good.
Black 2000 ML55 AMG - Bilstein shocks & Eibach springs - H&R anti-sway bars - 22x10.5" TSW Bremma Wheels - 295/30/22 Falken Ziex Tires - Powerchip ECU re-flash http://www.benzworld.org/forums/w163...ml#post2829197
porschenut is offline   Reply With Quote
Old 03-19-2008, 06:25 PM   #4 (permalink)
Date registered: May 2004
Vehicle: 2000 ML320
Check the other fuse box located behind the panel in the passenger footwell
Magweed is offline   Reply With Quote
Old 03-19-2008, 07:40 PM   #5 (permalink)
Date registered: Aug 2006
Vehicle: 02 ML320
For 2001 and above, it is fuse #6 in the right side foot well. If the fuse is not blown, you have burned out the contact in the socket and needs replacement.
43sqd is offline   Reply With Quote
A/C stopped working ~ no compressor or aux fan power somebeach W126 S,SE,SEC,SEL,SD,SDL Class 11 10-02-2006 08:05 PM
where to pickup 12v aux power at dash 1999slk230 R170 SLK Class 3 07-03-2006 04:50 AM
Glovebox AUX retrofit for Comand 2.0 pleubner W163 M-Class 34 02-02-2006 03:59 PM
Question: How to add an aux. 12v power outlet? Voortrekker W203 C-Class 4 01-09-2006 12:10 PM
Fog light/s AUX just stopped working paul W163 M-Class 2 04-15-2002 10:41 PM
