1999 ml430 rear door locks - Mercedes-Benz Forum
post #1 of 12 (permalink) Old 02-18-2008, 09:55 AM Thread Starter
Date registered: Feb 2008
locks machine gunning, now door wasn't latch, how does inside door skin come off.
dave5214072 is offline
post #2 of 12 (permalink) Old 02-18-2008, 10:57 AM
Date registered: Aug 2006
Vehicle: 02 ML320 06 ML500
Quoted: 910 Post(s)
Practically every new member does not fully complete the registration form by including the year and model of their vehicle. Please click on USER CP to the left, then click on EDIT PROFILE, scroll down to ADDITIONAL INFORMATION and insert the year and model of your truck.
The door lock actuator has to be replaced and it is not a job for a novice. If you cannot remove the door panel you will have much greater difficulty with the actuator.
File Type: pdf Door - Rear - Liner - remove&install.pdf (387.8 KB, 512 views)
43sqd is offline
post #3 of 12 (permalink) Old 02-18-2008, 04:47 PM
ACW
Vehicle: 1999 ML430
Do you have a pdf for the front door panel removal? I need to install sail panel tweeters and that would be a big help - might as well not go in blind...
ACW is offline
post #4 of 12 (permalink) Old 02-18-2008, 05:47 PM
Quoted: 910 Post(s)
It's really no different; the same set-up.
43sqd is offline
post #5 of 12 (permalink) Old 02-19-2008, 06:07 PM
ACW
Vehicle: 1999 ML430
I was thinking that knowing the location of all the clips could help me avoid breaking more than I would otherwise...
ACW is offline
post #6 of 12 (permalink) Old 02-21-2008, 06:28 AM
ACW
Vehicle: 1999 ML430
43sqd - can you please post that pdf whenever you get a chance? I would really appreciate it, thanks.
ACW
ACW is offline
post #7 of 12 (permalink) Old 02-21-2008, 07:22 AM
Quoted: 910 Post(s)
ACW
Here it is.
File Type: pdf Door - Front - Liner - remove&install.pdf (239.9 KB, 363 views)
43sqd is offline
post #8 of 12 (permalink) Old 02-21-2008, 08:19 AM
Quoted: 910 Post(s)
It would also be a good idea to get a tool like this to pry out the christmas tree clips on the door panel.
43sqd is offline
post #9 of 12 (permalink) Old 02-21-2008, 07:06 PM
ACW
Vehicle: 1999 ML430
Thank you for posting that, I reallly appreciate it.
ACW is offline
post #10 of 12 (permalink) Old 02-10-2012, 09:57 AM
Cuda426's Avatar
Date registered: Mar 2011
Vehicle: 1999 ML 430 / 1973 Porsche 914-4
My 1999 ML430 is doing the same thing on the driver side passenger door. I also cannot manually push the lock down. If the actuator is bad will it not allow you to push the lock down by hand? On my truck when you try to lock it, the knob bounces up and down as if something is blocking its travel? Any advice welcome, thanks.
Cuda426 is offline
    Rear door locks broken now what.. Kerr G-Class 9 12-07-2012 02:18 PM
    1999 Ml430 Rear Seat Rattle? DETANE W163 M-Class 0 04-13-2007 01:53 AM
    Rear door locks??? dosey W203 C-Class 2 10-05-2006 11:38 PM
    1999 ML430 rear rotor removal JAD W163 M-Class 12 10-11-2005 07:00 AM
    98ML320 rear door locks question Alster W163 M-Class 4 09-20-2001 08:06 PM
