Old 02-14-2008, 03:34 AM   #11 (permalink)
Date registered: Aug 2006
Vehicle: 02 ML320
When you originally started this thread, you simply said that you just replaced the conductor plate and listed the wrong DTC of P0175 (which is obviously P0715). You never stated why you did this repair in the first place. It's very difficult for anyone to assist you when you only listed the code, but not the problem/symptom(s) you were having prior to replacing the conductor plate.
How did you arrive at the fact that you needed a new conductor plate? Did someone tell you so? Was it simply because of the code? Did you read another thread which influenced you? What are the present codes?
43sqd is offline   Reply With Quote
Old 02-14-2008, 06:09 AM   #12 (permalink)
Vehicle: 2000 ML 320
Oil was checked with engine running.
I installed the conductor plate because the car was shifting erradically, then went into 1st gear limp mode. I pulled the code P0175 and after numerous forum checks, here and on mercedesshop and a friend at the dealer, all said that the speed sensor on the conductor plate was the issue with this code.
I replaced the conductor plate, removed 5.3-5.5L of oil, put back 3L to check level and it said it was nearly full. However, the tranny wouldnt engage any gear. So I added 1.5L more, it would then engage however I checked the level with the stick and it said it was over, so i removed 1 L and that put it at the max level. Now again, the tranny doesnt engage.
However, as my last msg stated, how can it be full if I removed 5.5L from the factory fill and only replaced 3.5L?
...with the tranny now not engaging again.
chlubb is offline   Reply With Quote
Old 02-14-2008, 06:32 AM   #13 (permalink)
eric242340's Avatar
Date registered: Nov 2007
Vehicle: S320
5.5 Ltr does seem a little high, we normally put 3 ltr and then start the engine and run the transmission through the gears after check the oil level and top up as required. Its possible that the valve body gasket is upside down and therefore blockin oil flow. Without the torque converter being drained, I dont know how you got so much fluid out
I would suggest you put back the same amount of fluid as was taken out and see what the effect is, maybe you have the wrong dipstick for your car
ERIC
eric242340 is offline   Reply With Quote
Old 02-14-2008, 08:48 AM   #14 (permalink)
Eric,
I have the 722.6 disptick for a 00ML320, that was what I was told was correct.
You mentioned something, a gasket. There was no gasket between any of the parts, valve body, etc. Where would this gasket be you are speaking of?
I dont know why so much came out either. It was more than expected.
But again, if I put anymore than 3.5 in the dipstick says I am over, it just doesnt make sense.
Old 02-14-2008, 02:35 PM   #15 (permalink)
well, i add the remainder of oil for a total of 5L. The tranny NOW engages.
How odd this was, for some reason I extracted a lot more than expected and the gauge didnt read correctly.
Now to get limp mode removed and see if that fixes my problems.
Old 03-31-2008, 04:22 PM   #16 (permalink)
RK430's Avatar
Date registered: Feb 2008
Vehicle: 2000 CLK 430
Problem fixed???
chlubb, how's your ML now? Have you find out what the problem was?
RK430
2000 CLK430
RK430 is offline   Reply With Quote
Old 03-31-2008, 05:57 PM   #17 (permalink)
Vehicle: 02 ML320
His last overall post was on 2/14, so it is safe to assume that he is not a member who visits the forum regularly. I would suggest sending him a PM and ask how he made out.
How much for a Transmission Conductor Plate gusdogg W203 C-Class 4 04-10-2008 08:47 AM
Transmission Problem, conductor plate? BNZLVR W208 CLK Class 3 10-31-2007 06:25 PM
P0715-Replaced Conductor Plate CEL still on! cal45fan W163 M-Class 4 09-18-2007 06:37 PM
P0715 Tranny Conductor Plate-need link cal45fan W163 M-Class 1 09-13-2007 01:15 PM
Conductor Plate Modification??? mkwabena75 W203 C-Class 4 09-10-2005 07:31 PM
