» Site Navigation
» Other Sites
Links
» Tire Upgrade Garage
Old 01-24-2008, 08:03 AM   #11 (permalink)
Merzatt
Merzatt's Avatar
Date registered: Nov 2007
Vehicle: '02 ML320
Originally Posted by gunaa View Post
Can you please tell me how to remove the HL bulb cover?
Pull it or twist? the windshield fluid tank is very close the HL.
I download the manual but does not say how to remove it.
Both bulb covers have a "locking tab". It should be very easy to remove. The difficult part (for me) was to lock the bulb in place. Make sure to use the Halogen bulbs from recommended manufacturers. A shop once installed made in China and lasted a month!
Merzatt is offline   Reply With Quote
Old 01-24-2008, 10:28 PM   #12 (permalink)
baggiole
Date registered: Jul 2006
Which headlight bulb is burned of your car?I think it can not take one month for you in China.It can not take you more time.
baggiole is offline   Reply With Quote
Old 01-25-2008, 07:50 AM   #13 (permalink)
gunaa
gunaa's Avatar
Bulb replaced at the dealer! (Silverstar Montreal)
$14.00 bulb free instalation!
Thanks Guys!
gunaa is offline   Reply With Quote
Old 05-11-2008, 03:26 PM   #14 (permalink)
agarg
Date registered: May 2008
Vehicle: 1998 M-320
Send a message via Skype™ to agarg
Where do you download the manual? Sorry by I am very new and own a 1998 ML-320 (AKA W163)
agarg is offline   Reply With Quote
Old 05-12-2008, 02:34 AM   #15 (permalink)
43sqd
Date registered: Aug 2006
Vehicle: 02 ML320
Call 800-367-6372, and for $17 plus tax, Mercedes will mail one to your home.
43sqd is offline   Reply With Quote
Old 05-12-2008, 05:38 PM   #16 (permalink)
Mateo320
Mateo320's Avatar
Date registered: Jan 2006
Vehicle: 1998 ML 320
Smile
$20 for a pair of bulbs
latex gloves (oils from your hands will cook on the surface of the bulb causing it to overheat & pop)
turn on the lights that needs replacing
go out and take a mental note which one needs replacing
turn off the lights
pop off the plastic covers that cover the bulbs behind the lenses
carefully wiggle off the wire to the bulb
unclip the bulb off the housing
replace w/ new bulb & reverse directions for re-install & check
(repeat if needed to the other bulb)
aa
Mateo320 is offline   Reply With Quote
Replacing dash bulbs WillieD W210 E-Class 3 09-27-2007 07:25 PM
Replacing cluster bulbs? 1985 300CD W124 E,CE,D,TD Class 4 12-01-2006 12:47 PM
Replacing center dash bulbs room for a pony W126 S,SE,SEC,SEL,SD,SDL Class 2 06-07-2006 04:58 PM
Replacing MB bulbs for Performance Halogen Bulbs MidLife Crisis R170 SLK Class 6 04-14-2006 09:41 PM
replacing headlight bulbs sagamol W124 E,CE,D,TD Class 6 01-06-2006 05:01 PM
