» Site Navigation
» Other Sites
Old 01-23-2008, 10:08 AM   #11 (permalink)
Merzatt's Avatar
Date registered: Nov 2007
Vehicle: '02 ML320
Originally Posted by NLH View Post
good luck with that one, I had the same exact problem on my '98. It was the flapper box and it cost me like $1200 to have it repaired. The part is pretty expensive and they have to take the whole dash out to get to it.
Sorry to hear that they charged you so much. I heard people paying over $1000 up to $2000 for such A/C actuator repairs. Parts are not the expensive item, it's the labor of removing the whole dash. However, as shown in the instructions posted by 43sqd, this job can be done by removing the instrument panel only, not the whole dash.
Merzatt is online now   Reply With Quote
Old 01-24-2008, 04:21 PM   #12 (permalink)
Date registered: Aug 2006
Thank you 43sqd for the detailed information. I will try to test it in the weekend. I will let you know.
Thanx again.
mfarag is offline   Reply With Quote
Old 01-24-2008, 05:13 PM   #13 (permalink)
Date registered: Feb 2006
That's great news (can be accessed thru the instrument panel). Wonder if the dealer really
knew this for the 1-2k job.
mlfun is offline   Reply With Quote
Old 01-24-2008, 05:41 PM   #14 (permalink)
Vehicle: 02 ML320
What do you think? They prey on the unwitting.
43sqd is offline   Reply With Quote
Old 02-01-2008, 04:58 PM   #15 (permalink)
Date registered: Jan 2008
thanks to all of you that replied to my posting (thread), I really appreciate the information and the links, pdf files. I don't know what I would have done without your assistance. I have an appointment with my independent repair shop.
ml320judy is offline   Reply With Quote
Old 02-02-2008, 12:41 AM   #16 (permalink)
pcy
Date registered: Feb 2005
Vehicle: '98 ML320, '97 328i
ml320judy, please let us know if your mechanic is able to access the part thru the instrument cluster opening. Thanks in advance.
pcy is offline   Reply With Quote
Old 02-02-2008, 02:56 PM   #17 (permalink)
nhoj_yelbom's Avatar
Date registered: Jun 2006
Originally Posted by MADSLEG View Post
I have OM for 98 ML in PDF file,let me know if you need it.
i could use a copy, i have 99 but im sure there close!!
nhoj_yelbom is offline   Reply With Quote
Old 05-14-2008, 05:42 PM   #18 (permalink)
Exclamation couldn't reach it.
I pulled out the radio and climate control, but could not reach anything. I don't think I can reach it from the middle console.
Old 05-14-2008, 08:42 PM   #19 (permalink)
Vehicle: 02 ML320
I think the smart thing to do is when the air changes from cold to hot, leave the truck running, open the hood and look down at the compressor and check to see that the compressor clutch is turning. The compressor clutch is the outer most part on the compressor. When the A/C in engaged that clutch must turn with the pulley. When the A/C in not engaged the clutch does not turn, just the pulley turns. Do you understand?
my 1998 ml320 stefan ml320 W163 M-Class 5 08-17-2006 07:03 PM
1998 ML320 for sale brianly W163 M-Class 15 01-21-2006 05:35 PM
1998 ML320 Nav CD dgrancell W163 M-Class 22 04-27-2005 12:00 AM
Questions on 1998-99 ML320 transmission problem autobahnNY W163 M-Class 5 07-06-2004 03:43 PM
1998 ML320 A/C Problem Saumil W163 M-Class 5 04-19-2004 08:57 PM
