Old 01-12-2008, 04:54 PM   #1 (permalink)
Date registered: Jul 2004
Vehicle: 2001 ML430 (Sport Package)
Send a message via AIM to taeschmt
Help with Installing an ML430 Fog Light
I own a 2001 ML430 and have a busted front fog light. Per review of my owner's manual, it contains instructions for replacing a fog light that appears to be a component of a headlamp assembly. I may be missing something, but my fog lights appear to be separate from the headlamp, thus I don't know if these instructions apply. My fog lights are below the actual headlight.
Thus, my question(s) - (1) Am I an idiot and am reading this manual incorrectly? (2) If not, could someone point me in the direction of instructions on how to replace the fog lights I am describing.
Thanks in advance.
taeschmt is offline   Reply With Quote
Old 01-13-2008, 03:55 AM   #2 (permalink)
Date registered: Aug 2006
Vehicle: 02 ML320
Release the tab (#2) and then with a hook pull out the lamp.
43sqd is offline   Reply With Quote
Old 01-13-2008, 05:59 AM   #3 (permalink)
FAR888's Avatar
Date registered: Mar 2007
Vehicle: '02 ML55 AMG
Send a message via Yahoo to FAR888
I own a 2001 ML430 and have a busted front fog light.....my fog lights appear to be separate from the headlamp, thus I don't know if these instructions apply
taeschmt, do you have an ML430 with the sport package?
The reason I ask is: the ML430 (1999-2001) without the sport package doesn't have fog lamps which are separate from the headlamps.
Only the ML430 with sport package has fog lights which are separate from the headlamp and integrated into the front bumper.
ps. Does the front of your ML430 look like mine in my avatar? If so you have the sport package and the procedure for removing the fog lights may be different from the instructions from the manual 43sqd kindly posted for you.
FAR888 is offline   Reply With Quote
Old 01-13-2008, 07:50 AM   #4 (permalink)
ML430 fog light
All - thanks for the responses. I am very impressed with how timely people respond on this board to help each other out. It's great.
FAR888 - I do have a sport package which looks exactly like yours. Any thoughts on other instructions?
Old 01-13-2008, 01:41 PM   #5 (permalink)
FAR888's Avatar
Sorry taeschmt, I am one of those forum members without a technical or DIY bone in my body and cant offer much help on this isssue.
I have a 2002 ML55 with the AMG sport package and round fog lights and my hand book instructions on removing the fog lights is the same as the instructions posted above by 43sqd which is for removing fog lights in stock MLs which come equipped with the angular fog lights.
I am sure that someone with a sport package ML or ML55, who has changed their fog lights, will chip in soon enough but do try doing a search on fog light removal and see from the profile of the poster whether the poster owns a sport package or ML55.
Best of luck!
ps. Please update your profile to show your location and more importantly your exact model type (2001 ML430 with sport package) as it helps forum members who are trying to help you. For eg. 43sqd is an experienced mechanic and if your profile had indicated that you had the sport package he would not have posted the instructions from the manual for a 2002+ ML.
Old 01-13-2008, 02:41 PM   #6 (permalink)
Date registered: Feb 2006
Stick around. The board is only as good as its participants.
mlfun is offline   Reply With Quote
Old 01-14-2008, 06:54 AM   #7 (permalink)
Ml430 Sport Fog Light
Fair enough. Unfortunately, I'm still struggling with this issue. Update on my progress thus far - I've popped off the fog light bumper cover and unscrewed the actual bulb assembly from the frame. However, I can't figure out how to disconnect the wiring. Does anyone have any suggestions?
Old 01-14-2008, 07:59 AM   #8 (permalink)
FAR888's Avatar
taeschmt,
I found this information using the search facility:
http://www.benzworld.org/forums/w163...?highlight=fog
The information you require is contained in pleubner's post #2
Hope this helps.
ps. Thanks for updating your profile!
Old 01-14-2008, 08:06 AM   #9 (permalink)
matman_forever's Avatar
Date registered: Nov 2007
Vehicle: ML430
While were on the subject of fog lights, my ML430 has an aux fog light button inside butno fog lights out. Does this mean that the previous owner sold them and if so how hard would it be to put new ones in.
Thanks,
Matt
matman_forever is offline   Reply With Quote
Old 01-14-2008, 08:16 AM   #10 (permalink)
FAR888's Avatar
Matt,
I read somewhere on this forum, a long time ago, that some MLs in different states in the US needed to have the fog light activated by the dealer.
All the information is on this forum but you must make use of the search facility - It is a great and invaluable source of information.
You will find that a lot of the more experienced members on this forum will probably not repond to some posts because they have been discussed so many times before and they expect new (or relatively new) members like yourself to use the search facility.
Good luck!
Ml430 Fog Light cal45fan W163 M-Class 3 11-01-2006 03:46 PM
installing new fog lights tresean1 W202 C-Class 5 02-08-2006 01:49 PM
im installing a fog light on my 2000 ML430 i need to know how i can hook the wiring. cueto W163 M-Class 2 04-11-2005 08:20 PM
While installing my fog light bulbs (which are GREAT!) I noticed> J-bird W163 M-Class 9 12-29-2003 12:20 PM
I will be installing my Hella DE fog... dewdaltz W163 M-Class 14 10-19-2003 09:37 AM
