fuel gauge - Mercedes-Benz Forum
post #1 of 18 (permalink) Old 12-16-2007, 10:23 AM Thread Starter
kelland's Avatar
Vehicle: ML430, LPG conversion, media center touch screen & headrest screens
fuel gauge
hi, my ever wonderful unreliable 2001 ml430 has now got the dreaded fuel gauge error and it always lies about how much fuel i have!
I've read a few forums on here and want to do the fuse reset option obviously my fuse box is by the drivers pedals as it is r/h drive but I dont know whether to pull fuse No.5 (7.5amp instrument cluster) or fuse No.13 (20amp electr. fuel pump)?? is my fuse layout the same as the U.S. ones??
regards
kelland is offline
post #2 of 18 (permalink) Old 12-16-2007, 10:29 AM
Date registered: Jan 2007
Vehicle: 06 ML500
I pull out the 7.5 instrument cluster fuse and usually does the trick....but eventually goes back to its usual woes.
Another member wired in a switch to that fuse and place it near the driver, not a bad idea.
lastprodigy is offline
post #3 of 18 (permalink) Old 12-16-2007, 10:53 AM
Date registered: Aug 2006
Vehicle: 02 ML320 06 ML500
Quoted: 882 Post(s)
regards
It is fuse #5 that you have to pull. The tech. bulletin also says that after the gauge registeres correctly, only refill the tank when it shows half full. Whether or not it works, I do not know but it might be worth a try..
43sqd is offline
post #4 of 18 (permalink) Old 12-16-2007, 11:35 AM
Bigburgundy's Avatar
Date registered: Jun 2007
Vehicle: 2004 ML500 w/ Sport Package
good luck. ive tried fixing this problem forever. no luck
Bigburgundy is offline
post #5 of 18 (permalink) Old 12-16-2007, 11:48 AM
Vehicle: ML550, W212 E350 4 matic, 1966 Corvette C2 convt.
Believe the only way to correct your and others problems permanently is to replace the fuel pump/sending unit with the latest part number. In very rare cases the problem is with the cluster and that must be replaced if thats the case to cure it permanently. Years ago I had this with my original 98 ML and also with my 01 E Class that only required replacement of the sending unit not the fuel pump. The 02 ML500 I had and my curent 06 never had this problem nor did my 05 E Class.
sosh is offline
post #6 of 18 (permalink) Old 12-16-2007, 05:21 PM
Date registered: Oct 2004
Vehicle: 99ML320
Do you pull the fuse out when the key is in position 0, 1, or 2?
NorCal_ML320 is offline
post #7 of 18 (permalink) Old 12-16-2007, 06:49 PM
i had my dealer pull the fuse out one day when it was in for service, but it didnt do ANYTHING. i agree, i think its the sending unit. why fuel pump though?
post #8 of 18 (permalink) Old 01-07-2008, 02:32 PM
tenmikemike's Avatar
Date registered: Nov 2006
Vehicle: ' 02 ML500
In the other thread the guy said the key was in position 2 but engine OFF!
tenmikemike is offline
post #9 of 18 (permalink) Old 01-08-2008, 01:22 PM
Date registered: Dec 2007
Vehicle: 2000 ML55
Yes, Position 2 (all the lights on the dash come on right before you would start it), but car not running.
Pull fuse when dash is lit (guages die), then plug fuse back in (will read correctly)
My 00 ML has this issue. Dealer said they would reprogram the cluster 1st (less than $80). If that does not fix the issue, then its on to the Fuel sender/pump replacement. (You generally replace both, becuase the sender sits on top of the FP, so while they are both out, you replace both)
UK
UrbanKnight is offline
post #10 of 18 (permalink) Old 01-09-2008, 12:39 PM Thread Starter
kelland's Avatar
UK
the first time i pulled the fuse it worked, the second time it stuck at the halfway point so to me its not an instant fix pulling the fuse!
kelland is offline
    Faulty Fuel Gauge or Fuel Sensor MB9900 W124 E,CE,D,TD Class 8 05-05-2013 08:51 PM
    The Ultimate Solution to the Fuel Gauge/Fuel Sending Unit Problem jengel111 W163 M-Class 4 03-10-2013 12:22 PM
    Changed my fuel pump to fix my fuel gauge, and got an added BONUS. mikewired W163 M-Class 15 03-04-2012 09:52 AM
    Problems fitting 500 fuel gauge-oil pres'-water temp gauge cluster to 560 clocks mutley666 W126 S,SE,SEC,SEL,SD,SDL Class 2 10-10-2005 10:03 AM
    Update on Fuel Gauge Problem: Got Fuel Pump Replaced Today tjhsiao W163 M-Class 4 10-25-2002 05:47 PM
