Does anyone have tire size 245/70 r16? i have that size on my ml320 and im wondering what psi should i run on it? currently i have 32 in the front and 36 in the rear. is this okay? should i drop it or increase it? help would be nice, Thanks
well my gas cap says recommend tire size is 255/65 16 and normal psi should be 29 all around and max is 32 front 36 rear and i dont have tire size 255/65 16. so im wondering if i should stick with the 32 front and 36 rear or maybe change it up a bit.
Do you guys want to know the proper way to figure out the required pressure?
Contact your tire manufacturer and get a load/pressure chart for the tires you are running. Then have your vehicle scaled at normal driving weight by axle. Divide that number by 2. Look at the load chart and see what pressure that tire requires to carry the load it is carrying. Adding any more pressure to that number is not needed.
well the manufacture recommends 32 front and 36 rear for tire size 255/65 16 and my tires are 245/70 16..so i dont know what to do. i might leave them at 33 all around
