Old 12-02-2007, 04:52 PM   #1 (permalink)
Date registered: Dec 2006
P0410=Headaches + $...Help!!!!!!!!
Well change the oil sender light is off>>>still coming up with p0410 checked air pump works, cleaned MAF, clean switch valves at both sides of the air pump they were dirty...my mechanic is telling me that there is an air tube that leads from the front to the back of the engine in the left that has to be removed because sometimes engine oild gets in there...does that make sense he says it has to be cleaned as well...P0410 is killing my pockets has any body figured this out?
raykartell is offline   Reply With Quote
Old 12-02-2007, 07:44 PM   #2 (permalink)
laxman0324's Avatar
Date registered: Nov 2005
Vehicle: 1997 Nissan Pathfinder SE
Send a message via AIM to laxman0324
i dont want to be negative but that code is the reason i sold...cleaned and tested everything, mb said computer needed replacement b/c it was not reading the samples right, 1k+
http://4x4country.net/register.php?REF=8187
1999 Mercedes-Benz ML 320 - updated headlights and chrome grill strips...sold
1996 Honda Accord LX - 2.2L 4cyl and newly replaced exhaust pipe and muffler, 17x7 ADR Venomous Rims...stolen
1997 Nissan Pathfinder SE - Clear turn signal lenses and Ravens spare tire cover
laxman0324 is offline   Reply With Quote
Old 12-02-2007, 11:53 PM   #3 (permalink)
Date registered: Aug 2006
Vehicle: 02 ML320
How could this code be killing your pockets when the only thing you did was clean two small valves? If you say the pump is working and the two valves are clean, the only thing left is the CHANGEOVER VALVE. The computer tells the changeover valve to open allowing vacuum to the two shut off valves.
Working with a cold engine, start the engine and immediately remove a vacuum hose from one of the shut off valves and check to see that there is vacuum. If there is then everything is in order.
43sqd is offline   Reply With Quote
Old 12-04-2007, 03:22 PM   #4 (permalink)
change over valve
Where can i find the chanfge over valve? is it in the back of the engine compartment.
Old 12-04-2007, 04:12 PM   #5 (permalink)
Vehicle: 02 ML320
Did you do the procedure I suggested?
Preventing Headaches/Headrushes dahappybanana Detailing and Car Care 6 06-25-2007 07:59 AM
Is this car worth all the headaches? bass1175 W140 S-Class 49 10-29-2006 07:08 AM
'86 300E starting headaches BrentGroth General Mercedes-Benz 1 11-25-2005 10:10 PM
AC Headaches Stan Pittman W201 190E, D-Class 1 05-04-2004 06:04 AM
Importation Headaches Kyle Holifield G-Class 8 07-01-2002 05:20 PM
