The MB power steering fluid is dealer list $9 a quart - sure, that's pricey but a top off, even a o-ring and/or reservoir replacement, will use less than a one quart..buying (2) quarts and having a full spare quart is still less than $20.
Where you don't double flush out all the existing fluid - then you can run into a compatibility problem between (2) different fluids/brands - why risk that on top-off/0-ring/reservoir anything less than a full fluid flush ?
I fully agree with fabbrisd1, don't mix two different fluids, I had to learn the hard way.
The MB Steering fluid is Pentosin according to my Sindelfingen Buddy's. They had a
meeting about it to change to a different Brand less expensive in the near future. Because the dealers are complaining about high price inventory.
By the way my local dealer charged me $16 for 1 Liter (1quart).
Vehicle: -06 ML500,-86 Monte SS,-88 Toyota Supra,-88 BMW 735iL ,-02 Avalanche Z71,-94 Cobalt 200,-97 Yamaha
Pentosin has 2 different (At least last time I checked) fluids
7.1 and 11 you cannot mix these so find out what is actually needed in your case and just use that.
Just my .02$
Thank you Finn1,
I'm sorry I didn't specify. I am asking for Power Steering fluid. I realy don't know what fluid is in my car right now. By the way the tank seem to be completly empty. Pentosin is it a power steering fluid? Is it a MB brand? Should I by MB brand and just fill my tank?
It is a power steering fluid.
The Pentosin has crept up in price to the point where if you need it quickly I would just
get the fluid from the dealer and be done with it. Getting it filled back to a proper level
as soon as possible is much more important than trying to save a few bucks on the Pentosin.
The Pentosin is excellent stuff, but can be hard to find locally. It is the CHF11S.
Also the Febi is just as good. Febi 08972. Both will blend fine with what is already in the
system if you can get it locally.
well today I replaced my reservoir and o ring(wanted to replace the C clip but the dealer didn't have one in stock). My 2002 ml320 had a bad leak before the change and power steering completely gave out. This leak was progresively getting worse over the last 2 months and I regret not doing it sooner, since it wasn't that difficult or time intensive. Before reading this forum I didn't realize that non MB ps fluid should be avoided and I put in generic ps fluid from the local car craft auto parts store. Today my intent ing was to drain out all the old fluid and replace with new MB fluid. I disconnected the lower power steering hose going to the radiator, and about 1/2 a quart of fluid came out, but I think most of it was from the radiator side and not from the ps pump side since this didn't seem to be the lowest point in the system. I put more fluid in the reservoir with the lower hose disconnected and more fluid came out, but again mostly from the radiator. I put everything back together and did the 50 turns lock to lock with the engine off and now it seems to be working fine. My question is; if there is still some inferior ps fluid in the system,am I looking at trouble down the road? If I should drain the system properly how do I get all the old fluid out, does anyone know specifically what to open up to drain all the ps fluid out?
