Transmission Experience Code P0715 - Mercedes-Benz Forum
post #1 of 15 (permalink) Old 11-28-2007, 10:00 PM Thread Starter
TimsML430's Avatar
Date registered: Nov 2005
Vehicle: 2000 ML430
I thought I would share my experience with everyone...
2000 ML430 (78,700 miles or 126,669 kms)
Occasional “Mechanical Limp Mode” noticed at 78,603 miles (126,500 kms). Truck would go into 3rd Gear only, but reset after 1 minute shut down, no CEL light. Then vehicle would resume normal functions.
Code is P0715, No CEL Light at this point.
Vehicle went into “Severe Limp Mode” 2nd Gear only, Nov 15, 2007 at 78,708 miles (126,669 kms) 9:15 pm. CEL light came on for the first time. Vehicle was driven directly to David Morris MB Dealership for Service.
I told Dealer that I would like a Transmission Fluid Service and further advisement to correct the problem.
Vehicle has some Oil Leak at 13 pin connector on Transmission.
After doing extensive research on this forum and others, I was convinced that I needed the Transmission Electrical Plate and Oil and Filter change.
What the Dealer did:
Test with Star Tester: 1.2 hrs $150.00
Replace Plate and
Perform oil and
Filter change: 4.5 hrs $562.50
Parts: 140 270 08 61 $260.60
Electric Kit
140 277 00 95 $18.79
Transmission Filter
140 271 00 80 $15.74
Gasket
203 540 02 53 $11.85
Spacer
140 991 00 55 $1.01
Pin
007603 010100 2 of @ $0.96
Transmission Seal Ring
001 89 21 03 10 7 of @ $19.85
Trans Fluid for 722.6
Labor: $712.50
Parts: $448.86
Shop Supp: $30.00
Tax: $71.48
Total: $1,262.84
Keep in mind, this is in CAN $
My comments:
They had my ML for 10 Days! No Loaner (My SA says she "tried her best") but they had a 2-3 week waiting list to get one. My Indy doesn’t do tranny work, unfortunately.
Looks like there are 2 modes of “Limp” and you only have a short amount of time or miles before it is “severe”.
Any thoughts or comments?
TimsML430 is offline
post #2 of 15 (permalink) Old 07-05-2009, 09:14 AM
Date registered: Nov 2003
Vehicle: 1999 e430
where is the 13 pin connection(turnine speed sensor)on a 1999 ml320
dtsva is offline
post #3 of 15 (permalink) Old 07-05-2009, 12:43 PM
Date registered: May 2004
Vehicle: 2000 ML320
the trans electrical (13 pin) connector is located on the passenger side just forward of the trans oil pan
Search "trans electrical connector"
Magweed is offline
post #4 of 15 (permalink) Old 07-06-2009, 05:31 AM
Date registered: Aug 2006
Vehicle: 02 ML320 06 ML500
Quoted: 909 Post(s)
Here is a photo of it.
43sqd is offline
post #5 of 15 (permalink) Old 07-06-2009, 06:03 AM
eric242340's Avatar
Quoted: 300 Post(s)
I have posted this problem with the electrical plate and the connector leak many times on Benzworld but not on this particular forum, so anyone reading this thread please change your transmission fluid at 60K Km or the equivelant in miles. It will save you a lot of money and time out for the car.
Preventative maintenance is better than an expensive cure.
ERIC.
eric242340 is offline
post #6 of 15 (permalink) Old 04-05-2010, 11:48 AM
Date registered: Mar 2010
Vehicle: 2000 ML320 130K
Im having the same problem. i replaced everything you wrote above and now my tranny still wont come out of limp mode. any ideas?
ahussain128 is offline
post #7 of 15 (permalink) Old 04-05-2010, 11:56 AM
Quoted: 909 Post(s)
That is because you must clear the codes from the Eng. Computer, Trans. Comp. and the Traction Control Comp. You will have to find a mechanic that has a professional grade scanner that can access and clear all three computers/modules.
43sqd is offline
post #8 of 15 (permalink) Old 04-05-2010, 11:59 AM
i did clear it from the engine computer, however im not sure if the scanner my mechanic used clears the other 2. i really appreciate your response because atleast i have a direction to head in now.
post #9 of 15 (permalink) Old 04-06-2010, 08:36 AM
so i verified that all the codes were cleared. and now im still having the same issue. still in limp mode. Im thinking of replacing the speed sensor, suggestions or comments?
post #10 of 15 (permalink) Old 04-06-2010, 12:24 PM
Darkmann's Avatar
Vehicle: 05 500
Quoted: 35 Post(s)
Interesting and very informative. Your vehicle doesn't really have that much mileage and this happened. It also sounds like you didn't buy used and you've maintained the vehicle as required.
For me, the lesson in all this is just what Eric said earlier - do the tranny fluid change somewhere between 60 and 100k. On my E, I did it at 60K and I gained mileage and shift efficiency. The ML is driven a lot less and 98% highway, so I'm targeting 80K. The 80K is based in discussions with my SA and my MB master-tech. Same who advised to do the E at 60K. Hopefully I'm not going to regret it.
1996 Z32 TT
A 18Hp lawn mower
370Z - I want one!
Darkmann is offline
    Help ERROR code P0715 EXR W163 M-Class 24 09-09-2013 07:24 PM
    code P0715 transmission 1999 c230 kompressor W202 C-Class 7 04-11-2013 07:18 AM
    My 430 in the shop because of code P0715 cal45fan W163 M-Class 6 09-25-2007 06:41 PM
    CEL code P0715 cal45fan W163 M-Class 6 08-18-2007 09:17 PM
    DTC P0715 - Please Help! SilverCloud97 W140 S-Class 1 12-25-2006 08:14 AM
