Old 11-15-2007, 05:32 AM   #1 (permalink)
FAR888's Avatar
Date registered: Mar 2007
Vehicle: '02 ML55 AMG
Send a message via Yahoo to FAR888
Question Intermittent ABS Light - What can I do to Resolve?
Hello Everyone,
My mother's '98 ML320 with 109,000 miles on the clock has recently developed an annoying ABS light.
The light would come on and then go off once the engine has been switched off and on again.
Please advise as to how to diagnose and resolve this problem without resorting to expensive and needless changing of perfectly functional parts.
Many thanks!
FAR888 is offline   Reply With Quote
Old 11-15-2007, 05:49 AM   #2 (permalink)
FAR888's Avatar
43sqd, please help!
Old 11-15-2007, 05:54 AM   #3 (permalink)
Date registered: Aug 2006
Vehicle: 02 ML320
This has always been a problem. So many systems are intertwined, but the cheapest fix du jour would be the brake light switch. Sometimes it works and others not. It's pretty cheap at about $15.
43sqd is online now   Reply With Quote
Old 11-15-2007, 06:07 AM   #4 (permalink)
FAR888's Avatar
Thanks for that 43sqd - I thought the brake light switch was only a remedy in relation to the BAS/ESP light problem.
The problem with my mother's '98 ML320 is to do with the ABS light only.
Old 11-15-2007, 06:26 AM   #5 (permalink)
Wolfgang's Avatar
Vehicle: MBs
FAR888, often the ABS light comes on due to a low voltage. If you want to know why it came on, have the Mercedes dealer hook up the diagnostic computer.
<a href="http://www.whnet.com/4x4/index.html"><img src="http://www.whnet.com/4x4/pix/ml_sign1.jpg" BORDER=0"></a>
Wolfgang is offline   Reply With Quote
Old 11-15-2007, 07:03 AM   #6 (permalink)
FAR888's Avatar
Wolfgang, I was hoping that you would respond - I shall do what you suggest right away.
Many thanks!
ABS acting up , srs light being funny , brakes weird, oil light sometimes flashes jimmypop W126 S,SE,SEC,SEL,SD,SDL Class 11 10-03-2007 06:04 PM
BAS / ESP Light Intermittent peid W163 M-Class 9 02-21-2006 06:25 AM
Intermittent Oil Light demmons65 W201 190E, D-Class 8 12-30-2005 10:30 PM
Intermittent Light Operation 92300CE W124 E,CE,D,TD Class 3 11-02-2005 11:25 AM
ABS light and (dim) battery light Steve420SEL W126 S,SE,SEC,SEL,SD,SDL Class 4 08-05-2003 05:46 PM
